It turns out that just putting idf_component.yml in your src directory tries to install the components. However, I get the following error
Processing 3 dependencies:
[1/3] espressif/esp-zboss-lib (1.2.1)
[2/3] espressif/esp-zigbee-lib (1.2.1)
[3/3] idf (5.1.2)
-- Configuring incomplete, errors occurred!
See also "/home/pepijn/Documents/PlatformIO/Projects/floracle/.pio/build/esp32-c6-devkitc-1/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any of the parent directories): .git
CMake Error at /home/pepijn/.platformio/packages/framework-espidf/tools/cmake/component.cmake:250 (message):
ERROR: 2 problems were found in the manifest file
/home/pepijn/Documents/PlatformIO/Projects/floracle/managed_components/espressif__esp-zboss-lib/idf_component.yml:
Invalid manifest format
Unknown keys: repository_info
SUGGESTION: This component may be using a newer version of the component
manager.
You can try to update the component manager by running:
/home/pepijn/.platformio/penv/.espidf-5.1.2/bin/python -m pip install --upgrade idf-component-manager
Call Stack (most recent call first):
/home/pepijn/.platformio/packages/framework-espidf/tools/cmake/build.cmake:574 (__component_get_requirements)
/home/pepijn/.platformio/packages/framework-espidf/tools/cmake/project.cmake:547 (idf_build_process)
CMakeLists.txt:3 (project)
I tried the suggestion but it doesn’t seem to do anything.
