hello
I’m trying to use the GPIO led pin by changing its registers but it is not working.
I’m using the following code which should select the pin for SIO operation, initialize the GPIO pin to output with the GPIO_OE reg(0x20) followed by setting them with GPIO_OUT (0x10)
Below you can find my code, what do i wrong, since it’s not working for me
#define baseAdress 0x00
#define PinMode *(int*)(baseAdress+SIO_GPIO_OE_OFFSET)
#define PinOut *(int*)(baseAdress+SIO_GPIO_OUT_OFFSET)
#define baseAdressFUNSEL 0x40014000
#define FUNSEL25 *(int*)(baseAdressFUNSEL+0xcc)
FUNSEL25=0x0005;
PinMode=0x2000000;
PinOut=0x2000000;
