Hello!
Thanks again for the help @maxgerhardt
So I am working on the board script. Have a question about this line:
MakeBoard("rpipico", "Raspberry Pi", "Pico", "0x2e8a", "0x000a", 250, "RASPBERRY_PI_PICO", 2, "boot2_w25q080_2_padded_checksum")
I can guess most of the fields from the func but just to be sure
# MakeBoard(name, vendor_name, product_name, vid, pid, pwr, boarddefine, flashsizemb, boot2, extra = None):
I understand we should use the standard vid field … If this is a custom board should we apply for a custom pid? Or can we use the generic pid field?
How do I specify the clock speed setting for this board if I want it to be pre-configured or pre-set? I imagine leaving blank means configurable in .ini?
And lastly the boot2 field… Is there someplace I can get more info?
I am cloning mostly values from generic since it works with my board except for a few pins that change from generic.
LAlso can I assume we do the PR to:
Will the changes also get pushed to:
or should we do a separate PR for the platform io repo?
Any help welcomed that can point me to the right direction!
