They say RF24 library (ID:433) is compatible with esp8266 core for Arduino. There is no “espressif” in library.json but I decided to give a try - the code compiles with Arduino IDE so there should be no problems, right?
Unfortunately it’s not as easy, while trying to compile a simple helloworld I got:
Build recurses into subdirectories of $HOME/.platformio/lib/RF24_ID433 and tries to build foreign code. How do I prevent this? I understand this code is be required for other platforms, is anything I could do in library.json to overcome this? Of course it will be possible to create separate library entry for esp8266 but i’m trying to avoid this.
PlatformIO 3.0 uses library.json when builds library. You can here test it
export includes/excludes relates to source code that should be exported to archive. Do you need it? You can resolve build process using build field and specify what need to build and etc.
For backward compatibility with Arduino 1.0.x, the library author may opt to not place source code into the root folder, instead of the folder called src. In this case the 1.0 library format is applied and the source code is searched from the library root folder and the utility folder, for example:
In file included from /home/jazg/.platformio/lib/RF24_ID433/RF24.cpp:10:0:
/home/jazg/.platformio/lib/RF24_ID433/RF24_config.h:124:0: warning: "PSTR" redefined [enabled by default]
#define PSTR(x) (x)
In file included from /home/jazg/.platformio/packages/framework-arduinoespressif/cores/esp8266/Arduino.h:240:0,
from /home/jazg/.platformio/lib/RF24_ID433/RF24_config.h:63,
/home/jazg/.platformio/packages/framework-arduinoespressif/cores/esp8266/pgmspace.h:21:0: note: this is the location of the previous definition
#define PSTR(s) (__extension__({static const char __c[] PROGMEM = (s); &__c[0];}))
/home/jazg/.platformio/lib/RF24_ID433/RF24_config.h:128:0: warning: "strlen_P" redefined [enabled by default]
#define strlen_P strlen
/home/jazg/.platformio/packages/framework-arduinoespressif/cores/esp8266/pgmspace.h:73:0: note: this is the location of the previous definition
#define strlen_P(strP) strnlen_P((strP), SIZE_IRRELEVANT)
/home/jazg/.platformio/lib/RF24_ID433/RF24_config.h:129:0: warning: "PROGMEM" redefined [enabled by default]
#define PROGMEM
/home/jazg/.platformio/packages/framework-arduinoespressif/cores/esp8266/pgmspace.h:18:0: note: this is the location of the previous definition
#define PROGMEM ICACHE_RODATA_ATTR
/home/jazg/.platformio/lib/RF24_ID433/RF24_config.h:130:0: warning: "pgm_read_byte" redefined [enabled by default]
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
/home/jazg/.platformio/packages/framework-arduinoespressif/cores/esp8266/pgmspace.h:90:0: note: this is the location of the previous definition
#define pgm_read_byte(addr) \
/home/jazg/.platformio/lib/RF24_ID433/RF24_config.h:131:0: warning: "pgm_read_word" redefined [enabled by default]
#define pgm_read_word(p) (*(p))
/home/jazg/.platformio/packages/framework-arduinoespressif/cores/esp8266/pgmspace.h:99:0: note: this is the location of the previous definition
#define pgm_read_word(addr) \
But I believe this is a problem with library itself when used with plain ESP8266, the macro ARDUINO_ARCH_ESP8266 should be defined only for Arduino DUE, not for plain ESP8266.
Okay then this is a bug somewhere. Either this macro should not be defined, or the definiton is used for wrong purpose. This has been reported already.
