Hello !
I’ve just began writing some code and I stumbled upon a scope error
The thing is that the same code compiles without errors or warnings in Arduino IDE.
The following code is a simplified version of my own code; it’s just a means of emulating the error:
main.cpp
void makeLog() {
String string = logPath(); // error: `logPath` was not declared in this scope
String logPath() {
String currentPath = "";
currentPath = "/logFile.txt";
return currentPath;
When attempting to build it, I have the following output:
src/main.cpp: In function 'void makeLog()':
src/main.cpp:5:27: error: 'logPath' was not declared in this scope
*** [.pioenvs/esp32doit-devkit-v1/src/main.cpp.o] Error 1
platformio.ini
[env:esp32doit-devkit-v1]
platform = https://github.com/platformio/platform-espressif32.git#feature/stage
board_build.flash_mode = qio
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
#libraries
#lib_deps = ESP Async WebServer
