I wanted to change only the name of the output firmware.bin
file to something like firmware_1.2.3+567.bin
, for this, I followed the example shown in the official documentation .
The 1st (not that bad) problem is:
Following the shown example does not only rename firmware.bin
but it also removes the extension of the .elf
file.
Indexing .pio\build\debug\libFrameworkArduino.a
Linking .pio\build\debug\firmware_0.1.0+1616706267 <<<==== SEE HERE
Retrieving maximum program size .pio\build\debug\firmware_0.1.0+1616706267
Checking size .pio\build\debug\firmware_0.1.0+1616706267
RAM: [= ] 12.1% (used 39724 bytes from 327680 bytes)
Flash: [======== ] 78.0% (used 1021724 bytes from 1310720 bytes)
Building .pio\build\debug\firmware_0.1.0+1616706267.bin
In addition (the 2nd problem):
When I want to upload the the code to my ESP32 MCU, it always fails because paritions.bin
file cannot be found:
Uploading .pio\build\debug\firmware_0.1.0+1616706267.bin
usage: esptool write_flash [-h] [--erase-all]
[--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--encrypt]
[--ignore-flash-encryption-efuse-setting]
[--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
esptool write_flash: error: argument <address> <filename>: [Errno 2] No such file or directory: 'C:\\Users\\ME\\Development\\MyProject\\Firmware\\.pio\\build\\debug\\partitions.bin'
*** [upload] Error 2
The problem comes for sure from renaming the file, because as soon as I remove the script from being executed from the extra_scripts
uploading works properly again.
Does anyone have any solution for the uploading problem? and maybe a way to avoid the first problem?
I cant reproduce the issue.
I’m using the platformio.ini
adapted for an ESP32 and the same Python code.
[env:env_custom_prog_name2]
build_flags = -D VERSION=13
extra_scripts = pre:extra_script.py
and
Import("env")
my_flags = env.ParseFlags(env['BUILD_FLAGS'])
defines = {k: v for (k, v) in my_flags.get("CPPDEFINES")}
# print(defines)
env.Replace(PROGNAME="firmware_%s" % defines.get("VERSION"))
and (Verbose) uploading gives me
Auto-detected: COM9
"c:\users\max\appdata\local\programs\python\python38\python.exe" "C:\Users\Max\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 --port "COM9" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 C:\Users\Max\.platformio\packages\framework-arduinoespressif32\tools\sdk\bin\bootloader_dio_40m.bin 0x8000 C:\Users\Max\Documents\PlatformIO\Projects\hallowing_repro\.pio\build\env_custom_prog_name2\partitions.bin 0xe000 C:\Users\Max\.platformio\packages\framework-arduinoespressif32\tools\partitions\boot_app0.bin 0x10000 .pio\build\env_custom_prog_name2\firmware_13.bin
esptool.py v3.0
Serial port COM9
Connecting........_
Chip is ESP32-D0WDQ6 (revision 0)
Features: WiFi, BT, Dual Core, Coding Scheme None
Crystal is 40MHz
MAC: 24:0a:c4:04:26:38
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 17104 bytes to 11193...
Writing at 0x00001000... (100 %)
Wrote 17104 bytes (11193 compressed) at 0x00001000 in 0.3 seconds (effective 438.9 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 564.8 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 1495.1 kbit/s)...
Compressed 201312 bytes to 106842...
Writing at 0x00010000... (14 %)
Writing at 0x00014000... (28 %)
Writing at 0x00018000... (42 %)
Writing at 0x0001c000... (57 %)
Writing at 0x00020000... (71 %)
Writing at 0x00024000... (85 %)
Writing at 0x00028000... (100 %)
Wrote 201312 bytes (106842 compressed) at 0x00010000 in 2.9 seconds (effective 561.8 kbit/s)...
Leaving...
Hard resetting via RTS pin...
============== [SUCCESS] Took 12.55 seconds ==============
And all the files are there, especially the partition file.
Do you get a different result when using the exact same files per above?
PS: My versions are
PLATFORM: Espressif 32 (3.1.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10005.210308 (1.0.5)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
at pio --version
PlatformIO Core, version 5.2.0a3`.
After seeing that it works on your side @maxgerhardt , I kept trying until I figured out what causes the problem.
The problem is the semantic versioning format. In the platformio.ini
, I have the following:
firmware_version = '"0.1.2+3"'
-D FIRMWARE_VERSION=${common.firmware_version}
As soon as I add the +
to the version, the problem appears, removing the plus symbol solves the problem . I am trying to find a workaround this. Please let me know if you have any suggestions.
P.S., adding -
instead of +
also causes the same issue.
UPDATE:
It turns out that adding any kind of characters (also english letters) in place of symbol causes the same issue. Weird.
Also hard coding the value in the python code causes the same problem. Please check these test cases:
env.Replace(PROGNAME="firmware_0.1.2+3") # <<== ISSUE TOO
env.Replace(PROGNAME="firmware_012+3") # <<== This works (notice: no periods)
env.Replace(PROGNAME="firmware_0.12+3") # <<== ISSUE TOO (one period in the string makes it does not accept characters other than digits and periods after that period, apparently).
Any ideas what is happening and how to solve this? Seems to be a bug?
@ivankravets could you also please take a look?
@maxgerhardt were you able to reproduce the issue using the format I showed in my previous analysis?
UPDATE:
After spending the whole day trying to understand and fix this, I believe this is a bug. I opened an issue on GitHub:
opened 01:25AM - 27 Mar 21 UTC
closed 02:09PM - 02 Apr 21 UTC
bug
build system
I want to rename the output `firmware.bin` file according to the example supplie… d by [the official documentation](https://docs.platformio.org/en/latest/projectconf/advanced_scripting.html#custom-firmware-program-name).
#### platformio.ini:
[env:env_custom_prog_name]
platform = espressif8266
board = nodemcuv2
#### extra_script.py:
Import("env")
# print(defines)
The default empty `main.cpp` file is sufficient to reproduce the problem.
The previous default example will work. **However, as soon as I use the `PROGNAME` `1.2.3+4` (which includes dots), the program does not build properly anymore. It removes the extension of the `,elf` file, and the `partitions.bin` is missing (which causes fail to upload).**
So in other words, for the example above, the problem is reproducible as soon as I use the following semantic `VERSION` instead of `13`: **`1.2.3+4`**
The problem happens exactly because there is a dot inside the the `PROGNAME`. Could you please check it?
Please let me know if otherwise.
I could reproduce the issue with the minimal
Import("env")
and this indeed causes the partitions.bin
as well idedata.json
file to be missing, although the firmware name has been applied.
So maybe it’s something specific to the Espressif32 platform. The issue should be the way to go from here.
Thank you Max for your reply.
Sorry I did not understand what you mean? You mean the GitHub issue I opened?
Yes exactly, that should be the right starting place (even it has to be transfered maybe )
