How to remove warning Couldn't extract the list of installed Python packages
Actually there’s no problem, but that warning is annoying me because it tried attempting uninstall every time I want upload and build.
This is full output:
Processing esp32dev (platform: espressif32; framework: espidf; board: esp32dev)
PLATFORM: Espressif 32 (4.2.0) > Espressif ESP32 Dev Module
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, ol
imex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.40302.0 (4.3.2)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-mkfatfs @ 2.0.1
- tool-ninja @ 1.9.0
Warning! Couldn't extract the list of installed Python packages.
Installing ESP-IDF's Python dependencies
Collecting cryptography<35.0.0,>=2.1.4
Using cached cryptography-3.4.8-cp36-abi3-win_amd64.whl (1.6 MB)
Collecting future>=0.15.2
Using cached future-0.18.2-py3-none-any.whl
Collecting pyparsing<2.4.0,>=2.0.3
Using cached pyparsing-2.3.1-py2.py3-none-any.whl (61 kB)
Collecting kconfiglib==13.7.1
Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.1-cp39-cp39-win_amd64.whl (179 kB)
Collecting pycparser
Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Installing collected packages: pyparsing, pycparser, kconfiglib, future, cffi, cryptography
Attempting uninstall: pyparsing
Found existing installation: pyparsing 2.3.1
Uninstalling pyparsing-2.3.1:
Successfully uninstalled pyparsing-2.3.1
Attempting uninstall: pycparser
Found existing installation: pycparser 2.21
Uninstalling pycparser-2.21:
Successfully uninstalled pycparser-2.21
Attempting uninstall: kconfiglib
Found existing installation: kconfiglib 13.7.1
Uninstalling kconfiglib-13.7.1:
Successfully uninstalled kconfiglib-13.7.1
Attempting uninstall: future
Found existing installation: future 0.18.2
Uninstalling future-0.18.2:
Successfully uninstalled future-0.18.2
Attempting uninstall: cffi
Found existing installation: cffi 1.15.1
Uninstalling cffi-1.15.1:
Successfully uninstalled cffi-1.15.1
Attempting uninstall: cryptography
Found existing installation: cryptography 3.4.8
Uninstalling cryptography-3.4.8:
Successfully uninstalled cryptography-3.4.8
Successfully installed cffi-1.15.1 cryptography-3.4.8 future-0.18.2 kconfiglib-13.7.1 pycpars
er-2.21 pyparsing-2.3.1
[notice] A new release of pip available: 22.1.2 -> 22.2
[notice] To update, run: python.exe -m pip install --upgrade pip
Found 0 compatible libraries
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 3.9% (used 12904 bytes from 327680 bytes)
Flash: [== ] 15.8% (used 165841 bytes from 1048576 bytes)
AVAILABLE: cmsis-dap, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-
Looking for upload port...
Auto-detected: COM5
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v3.3
Serial port COM5
Connecting....
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:c6:f7:20:71:64
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00007fff...
Flash will be erased from 0x00010000 to 0x00038fff...
Compressed 26256 bytes to 16028...
Writing at 0x00001000... (100 %)
Wrote 26256 bytes (16028 compressed) at 0x00001000 in 0.8 seconds (effective 274.1 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.1 seconds (effective 186.2 kbit/s)...
Compressed 166224 bytes to 86297...
Writing at 0x00010000... (16 %)
Writing at 0x0001b2ac... (33 %)
Writing at 0x00020a39... (50 %)
Writing at 0x00026364... (66 %)
Writing at 0x0002fb34... (83 %)
Writing at 0x00036f58... (100 %)
Wrote 166224 bytes (86297 compressed) at 0x00010000 in 2.6 seconds (effective 504.7 kbit/s)..
Leaving...
Hard resetting via RTS pin...
=============================== [SUCCESS] Took 99.53 seconds ===============================
