I have setup remote development and successfully uploaded firmware to an ESP32-DevKit board.
However, I can’t find an option anywhere to upload the “Filesystem Image”.
Is there a way to do this with Platformio’s remote development?
I also don’t see this option in the graphical interface, i.e. just
but per documentation you should be able to open a CLI and execute
pio remote -t uploadfs --force-remote
to trigger the remote filesystem upload.
EDIT: Added --force-remote
to make it actually work.
Thanks maxgerhardt, I had been looking under pio remote, when I need to look under pio run. I tried your suggestion but needed to add run
and specify my environment.
It appears to build the filesystem but fails to updload with message
“Could not find the file with partitions table.”
Any suggestions appreciated.
Abbreviated output below:
$ pio remote run -e esp32dev -t uploadfs -v
Building project locally
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino; lib_deps: bblanchon/ArduinoJson@^6.17.2, FS, SPIFFS, davetcc/IoAbstraction@^1.6.7; test_port: COM13; test_ignore: test_desktop; build_flags: -Wno-packed-bitfield-compat, -Wno-parentheses)
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 38 compatible libraries
|-- <ArduinoJson> 6.17.3 (/home/dobrien/workspace/MB_P0003_SerialUI/.pio/libdeps/esp32dev/ArduinoJson)
|-- <FS> 1.0 (/home/dobrien/.platformio/packages/framework-arduinoespressif32/libraries/FS)
|-- <SPIFFS> 1.0 (/home/dobrien/.platformio/packages/framework-arduinoespressif32/libraries/SPIFFS)
"mkspiffs_espressif32_arduino" -c data -p 256 -b 4096 -s 1507328 .pio/build/esp32dev/spiffs.bin
/factory_config.json
=========================================================================== [SUCCESS] Took 0.95 seconds =============================================================================
Environment Status Duration
esp32dev SUCCESS 00:00:00.952
native IGNORED
=============================================================================== 1 succeeded in 00:00:00.952 ===============================================================================
Uploading firmware remotely
========================== [FAILED] Took 0.69 seconds ==========================
esp32dev FAILED 00:00:00.692
native IGNORED
==================== 1 failed, 0 succeeded in 00:00:00.692 ====================
Can you try pio remote -t uploadfs --force-remote -v
instead?
What is the platformio.ini
of the project?
Thanks maxgerhardt. I really appreciate your help.
pio remote run -t uploadfs --force-remote -v
or
pio remote run -e esp32dev -t uploadfs --force-remote -v
successfully uploads the filesystem remotely for me.
Do you want to edit your solution to include the missing ‘run’ command and I’ll mark it as the solution for others to find (your command as written fails).
In summary, I can use the pio remote by forcing remote build which resolves the issue for me. However, I don’t understand why it won’t work without forcing. Happy to run more tests if it is valuable to track down the cause.
Also here is my platformio.ini file for the project
FS
SPIFFS
test_port = COM13
test_ignore = test_desktop
-Wno-parentheses
[env:native]
platform = native
test_ignore = test_embedded, test_common
lib_compat_mode = off
https://github.com/maxgerhardt/ArduinoFake.git
; map conversion arrays to 0.
; will crash if anyone tries to use it, but shouldn't be used.
-D port_to_output_PGM=(uint8_t*)0
-D digital_pin_to_port_PGM=(uint8_t*)0
-D port_to_input_PGM=(uint8_t*)0
-Wno-parentheses
For context my use case is:
- ESP32-Devkit-VE connected via USB to windows 10 host machine running platformio
- Ubuntu 18.04 VM running on Hyper-V as I want to develop using platformio on linux VM
- Using platformio remote because no usb pass through is possible from Linux VM via Hyper-V
Maybe @ivankravets knows more about this, or it can be added in the docs for ‘Remote Uploading Filesystem Image’ for ESP32 (and ESP8266 I guess).
