I have 8 defined structures that are named the same with just an incrementing number on the end (i.e., label1, label2 …). I have a routine that gives me an int 1-8. Is there a way to refer to the individual structure using that int value?
This screams “use an array”.
Instead of
my_struct_t object1;
my_struct_t object2;
my_struct_t object3;
my_struct_t object8;
Refactor to →
// Array of 8 such structs
my_struct_t objects[8];
So that you can do this
//access with
my_struct_t* pStruct = &objects[some_index_i];
pStruct->some_value = 123;
// or directly
objects[some_index_index_i].some_value = 123;
Otherwise you are forced to do unholy things
my_struct_t* pStructs[8] = {
&object1, &object2, &object3, &object4,
&object5, &object6, &object7, &object8
my_struct_t* pStruct = pStructs[some_index_i];
I should have mentioned that the structures are created by a Squareline Studio project for the GUI. I don’t create the structures.
I see. If you want a mapping from int
to your struct then, you would need either the pointer array per above or a mapping function (switch(the_index) { case 0: return &label1; case 1: return &label2; ..}
Not at runtime, no.
Why not use an array of structs?
typedef struct fred {
int wilma;
int bambam;
} fred_t;
fred_t stuff[] = {
{0,0},
{1,1},
{2,2},
{3,3},
{4,4},
{5,5},
{6,6},
{7,7}
const uint8_t LIMIT = sizeof(stuff)/sizeof(stuff[0]);
Serial.begin(9600);
for (byte x = 0; x < LIMIT; x++) {
Serial.print(x);
Serial.print(": ");
Serial.print(stuff[x].wilma);
Serial.print(',');
Serial.println(stuff[x].bambam);
Running this, and opening the device monitor, gives:
0: 0,0
1: 1,1
2: 2,2
3: 3,3
4: 4,4
5: 5,5
6: 6,6
7: 7,7
So, you can do something similar i your code, get rid of the numeric suffixes, and choose your structure at will.
HTH.
Cheers,
Norm.
@maxgerhardt beats me to it yet again!
Cheers,
Norm.
Using switch does work, I was just trying to reduce my code. I tried the pointer array but it throws errors:
src/main.cpp:87:130: error: cannot convert ‘lv_obj_t**’ {aka ‘_lv_obj_t**’} to ‘lv_obj_t*’ {aka ‘_lv_obj_t*’} in initialization
lv_obj_t* medLbl[8] = { &ui_lblMed1, &ui_lblMed2, &ui_lblMed3, &ui_lblMed4, &ui_lblMed5, &ui_lblMed6, &ui_lblMed7, &ui_lblMed8};
Your ui_lblMed1
etc. variables are already lb_obj_t*
so you don’t need the &
in the array initialization. You’ll be copying the pointer’s value, aka the address they point at, which should be fine.
lv_obj_t* medLbl[8] = { ui_lblMed1, ui_lblMed2, ui_lblMed3, ui_lblMed4, ui_lblMed5, ui_lblMed6, ui_lblMed7, ui_lblMed8};
I’m still rather new to c++ and I still don’t have a good handle on pointers. Taking out the & works and will allow my code to be cleaner!
Thank you Max!
Bill
Instead of experimenting with C++ if you don’t have much experience, I strongly suggest to start with plain C language, and read The C programming Language - Brian Kernighan and Denis Ritchie. Any ancient free download Visual Studio suite such as VS 2012 or VS Express, will be a perfect aid for your coding.
Your problem is a nice, basic example of an array of struct, simply indexed by an int (a single number). Unless something more complicated required, no pointers are needed.
Cheers
