Redirect ESP32 log messages to SD card
Hey, I use ESP32 with arduino framework. For remote debugging, I want to store system logs like errors or warnings to the SD card together with my own log statements. Therefore, I created a callback function, which should be called when ESP_LOGE or ESP_LOGW is used, by exploiting esp_log_set_vprintf(sdCardLogOutput). However, the callback function is never called and only the ESP_LOGE is printed to the terminal via UART.
This is my code example:
#include "FS.h"
#include <SD.h>
#include "SPI.h"
#include "esp_log.h"
#define TAG "myApp"
#define LOG_LEVEL ESP_LOG_INFO
#define MY_ESP_LOG_LEVEL ESP_LOG_WARN
File logFile;
int sdCardLogOutput(const char *format, va_list args)
	Serial.println("Callback running");
	char buf[128];
	int ret = vsnprintf(buf, sizeof(buf), format, args);
	if (logFile)
		logFile.println(buf);
		logFile.flush();
	return ret;
void setup()
	Serial.begin(9600);
	delay(1000);
	while (!Serial)
	if (SD.begin())
		Serial.println("Successfully initialized SD card");
	else
		Serial.println("SD card failed");
	logFile = SD.open("/log.txt", FILE_WRITE, true);
	if (!logFile)
		Serial.println("Failed to open log file");
	else
		Serial.println("Setting log levels and callback");
		esp_log_level_set("*", MY_ESP_LOG_LEVEL);
		esp_log_level_set(TAG, LOG_LEVEL);
		esp_log_set_vprintf(sdCardLogOutput);
void loop()
	ESP_LOGE(TAG, "Error message");
	ESP_LOGW(TAG, "Warning message");
	delay(1000);
Besides, this is my platformIO.ini file:
[env:firebeetle32]
board = firebeetle32
build_flags = -DUSE_ESP32_LOG
Any idea why
  • My callback is never invoked
  • Only the error message is printed but not the warning message although my log levels should allow for this
There’s exactly 0 references to a USE_ESP32_LOG macro in the entirety of Arduino-ESP32.
https://github.com/search?q=repo%3Aespressif%2Farduino-esp32%20USE_ESP32_LOG&type=code
The is however USE_ESP_IDF_LOG. That would make Arduino use the esp_log_.. system.
But to get that to compile you have to go follow the ESP_LOGE macro to get to esp32-hal-log.h and uncomment the missing
and define the maximum log level (this checks it at the macro level, the inner log function will check it against the log level of the tag)
So in total I have a build_flags of
build_flags= -DUSE_ESP_IDF_LOG -DLOG_LOCAL_LEVEL=5
with a minimal source code of
#undef TAG // from Arduino.h
#define TAG "myApp"
    char buf[128];
    Serial.print(buf);
    return ret;
void setup()
    delay(1000);
    while (!Serial)	{	}
void loop()
    ESP_LOGI(TAG, "Info message");
    ESP_LOGV(TAG, "Verbose message"); // must not print, for our tag we set it to info
    delay(1000);
and that continuously outputs
Callback running
E (79794) myApp: Error message
Callback running
W (79794) myApp: Warning message
Callback running
I (79794) myApp: Info message
Note that this is not what you may want. You may want to work with the ArduHAL logging system used by default. I’ll leave that research to you.
Thanks for the elaborate answer.
First what do I want in a little more detail:
  • I want to redirect errors produced by libraries to the SD card for remote debugging, e.g. [E][WiFiSTA.cpp:232] begin(): SSID too long or missing!
  • I want to store my “self made” print statements for debugging on the SD card, too, e.g. ESP_LOGI(ESP_LOG_INFO, TAG, "This is info");
Approach 1: USE_ESP_IDF_LOG
I was able to reproduce your code and forward the messages to the SD card.However, I get flooded with warnings regarding redefinition of log_x functions during compilation. I was not able to test if the libary calls get forwarded, too, but I believe they will be.
Approach 2: ArduHAL
Using these build_flags=-DCONFIG_ARDUHAL_ESP_LOG -DCORE_DEBUG_LEVEL=5 I am not getting warnings, but the messages are only printed to the serial port, but not to the SD card.
Besides, I get compile Warning for both build flags stating the options are unknown:
Warning! Ignore unknown configuration option -dconfig_arduhal_esp_log -dcore_debug_level in section [env:firebeetle32]
Another disadvantage of approach 1 is messing with the library header files, which can always leads to errors during development when different people work on a project. So could you advice me on how to proceed to use the ArduHal approach redirecting the prints to the SD card?
Are you sure you’ve made the modificaiton in esp32-hal-log.h with commenting in the
//#ifndef TAG
//#define TAG "ARDUINO"
//#endif
block so that it becomes
#ifndef TAG
Yes I uncommented everything otherwise I would not compile at all. I just retried.
[env:firebeetle32]
#ifdef USE_ESP_IDF_LOG
#ifndef TAG
#define log_n(format, ...) myLog(ESP_LOG_NONE, format, ##__VA_ARGS__)
#else
In file included from C:/Users/Slevin/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal.h:76,
                 from C:/Users/Slevin/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:36,
                 from src/main.cpp:1:
C:/Users/Slevin/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-log.h:195: warning: "log_n" redefined
This is one of the many all similar looking warnings (not errors).
No keep that line commented.
So, I came a big step forward.
In esp32-hal-log.h I have now:
#ifndef TAG
#define TAG "myAPP"
//#define log_n(format, ...) myLog(ESP_LOG_NONE, format, ##__VA_ARGS__)
#else
My platformio.ini looks like:
[env:firebeetle32]
build_flags= -DUSE_ESP_IDF_LOG -DCORE_DEBUG_LEVEL=5
Note that I am now using CORE_DEBUG_LEVEL instead of LOG_LOCAL_LEVEL
With the CORE_DEBUGL_LEVEL constant I can set the logging level at compilation. Afterwards, I can use esp_log_level_set(TAG, LOG_LEVEL) to change the logging level for different TAGs during runtime.
It is important to know, that you cannot set higher logging levels than defined with CORE_DEBUG_LEVEL. If you do, esp_log_level_set() does nothing - at least from my experience.
The following code example can be used to get familiar with the logging capabilities:
#include "FS.h"
#include <SD.h>
#include "SPI.h"
#include "esp32-hal-log.h"
#define LOG_LEVEL ESP_LOG_WARN
#define MY_ESP_LOG_LEVEL ESP_LOG_INFO
File logFile;
	char buf[128];
	if (logFile)
		logFile.print(buf);
		logFile.flush();
	return ret;
void setup()
	Serial.begin(9600);
	delay(1000);
	while (!Serial)
	if (SD.begin())
	else
	logFile = SD.open("/log.txt", FILE_APPEND);
	if (!logFile)
	else
		esp_log_level_set("TEST", LOG_LEVEL);
		esp_log_level_set(TAG, MY_ESP_LOG_LEVEL);
void loop()
	for (int i = 0; i < 100; i++)
		ESP_LOGI("TEST", "Info message");
		ESP_LOGD(TAG, "Verbose message"); // must not print, for our tag we set it to info
Thank you for your help Max.
Hey,
I have the same issue,
I found some workaround without changing a core file, creating a custom command that calls a custom function
void esp_log_vprintf(esp_log_level_t level, const char* format, ...);
#define CFORMAT(level, latter, format, ...) esp_log_vprintf(ESP_LOG_INFO, ARDUHAL_LOG_FORMAT(latter, format), ##__VA_ARGS__)
#define CESP_LOGE(tag, format, ...)  log_e("[%s] " format, tag, ##__VA_ARGS__); CFORMAT(ESP_LOG_ERROR, E, "[%s] " format, tag, ##__VA_ARGS__)
#define CESP_LOGW(tag, format, ...)  log_w("[%s] " format, tag, ##__VA_ARGS__); CFORMAT(ESP_LOG_WARN, W, "[%s] " format, tag, ##__VA_ARGS__)
#define CESP_LOGI(tag, format, ...)  log_i("[%s] " format, tag, ##__VA_ARGS__); CFORMAT(ESP_LOG_INFO, I, "[%s] " format, tag, ##__VA_ARGS__)
#define CESP_LOGD(tag, format, ...)  log_d("[%s] " format, tag, ##__VA_ARGS__); CFORMAT(ESP_LOG_DEBUG, D, "[%s] " format, tag, ##__VA_ARGS__)
#define CESP_LOGV(tag, format, ...)  log_v("[%s] " format, tag, ##__VA_ARGS__); CFORMAT(ESP_LOG_VERBOSE, V, "[%s] " format, tag, ##__VA_ARGS__)
void esp_log_vprintf(esp_log_level_t level, const char* format, ...) {
  va_list arg;
  va_start(arg, format);
  char buf[1024];  // Buffer for storing log message
  int len = vsnprintf(buf, sizeof(buf), format, arg);
  va_end(arg);
  // Write log message to SPIFFS
  File logFile = SPIFFS.open("/logs.txt", "a");
  if (!logFile) {
    _PL("Failed to open log file");
  logFile.write((const uint8_t*)buf, len);
  logFile.close();
Thank you for your follow up.
But I have a few questions.
  • The callback function esp_log_vprintf() is triggered by calling CESP_LOGI() but also by logging messages generated by core functions using ESP_LOGI()?
  • How do you set the global logging level?
  • Can you set different logging levels for different tags?
Thank you for your questions,
  • The esp_log_vprintf() is called by CESP_LOGI() as a command, so the callback work only by direct call to CESP_LOGI(),
    unfortunately, I didn’t find a way to use the callback from the core functions, for example, BLE (it is just a workaround, of course, the best solution is a callback from the <esp_log.h>)
  • you can add a condition if(level <= CORE_DEBUG_LEVEL)
  if(level <= CORE_DEBUG_LEVEL) {
    va_list arg;
    va_end(arg);
    if (!logFile) {
    logFile.close();
  • you can implement it with some map
std::map<String, int> tagToLevelMap = {
  {"main", 3},
  {"file1", 4},
 `if(level <= CORE_DEBUG_LEVEL || level <= tagToLevelMap[tag]) `
Thanks for this thread! I had a similar problem and it helped!
I would like to share my solution that doesn’t require esp32-hal-log.h modifications.
It’s possible to define TAG via compiler flags:
build_flags = -DUSE_ESP_IDF_LOG -DLOG_LOCAL_LEVEL=5 -DTAG="\"ARDUINO\""
Thank you very much for this simple solution. Now I can dynamically set log levels per module with esp_log_level_set(), which didn’t work with the mapped Arduino logging.
Only - now the colors in the VS Code Terminal are gone. I used to have DCONFIG_ARDUHAL_LOG_COLORS=1 set in platform.ini, however that has now no effect anymore.
Does anyone know how to turn color codes back on? Thank you!
Peter
CONFIG_LOG_COLORS
Can restore colors
Fantastic and simple explanation as usual, thank you so much @maxgerhardt! I have re-purposed this to log to MQTT and I’m very happy with the result.
This one discussion clears up so much about using ESP_LOGx style logging that I couldn’t find anywhere else. I have converted almost totally from Serial.print now.
@hulakov WOW!!! THANK YOU!!! Those three build_flags were the trick. I only needed to include esp_log.h and did not need to include esp32-hal-log.h
but can someone explain why these three build_flags are the trick? (especially the last one) Having a solution is great but learning why it works would be even better.
-DUSE_ESP_IDF_LOG
-DTAG="\"ARDUINO\""
I was so darn happy to get this working that I created a library…
This will allow you to log all ESP_LOG output to a file either on LittleFS or on an SD card while also getting Serial output of the ESP_LOG messages.
You can turn the logging to the file or to Serial on and off independently anywhere in your code. Supporting functions include outputting the log file.
This is my first public library, so be kind.
