Redefinition of Symbols( defines, functions, etc) if lib_deps are used
Hello everyone,
I just discovered plattformio and currently trying it out. I must say its bit difficult.
I use the STM32F746G-DISCO with the mbed as a framework. To get the touchscreen demo running I want to install the following libraries:
  • BSP_DISCO_F746NG,
  • LCD_DISCO_F746NG,
  • TS_DISCO_F746NG
installing them worked fantastically. building them not so much. I get tons of errors of the following kind:
In file included from C:\Users\johannes\.platformio\lib\cmsis-core_ID1237\source\cmsis_nvic.c:31:0:
C:\Users\johannes\.platformio\lib\cmsis-core_ID1237/cmsis-core/cmsis_nvic.h:37:0: warning:
"NVIC_USER_IRQ_OFFSET" redefined
#define NVIC_USER_IRQ_OFFSET YOTTA_CFG_CMSIS_NVIC_USER_IRQ_OFFSET
In file included from C:\Users\johannes\.platformio\packages\framework-
mbed\targets\TARGET_STM\TARGET_STM32F7\TARGET_STM32F746xG\device/stm32f746xx.h:190:0,
mbed\targets\TARGET_STM\TARGET_STM32F7\TARGET_STM32F746xG\device/stm32f7xx.h:140,
mbed\targets\TARGET_STM\TARGET_STM32F7\TARGET_STM32F746xG\device/cmsis.h:35,
from C:\Users\johannes\.platformio\lib\cmsis-core_ID1237/cmsis-core/cmsis_nvic.h:35,
C:\Users\johannes\.platformio\packages\framework-mbed\cmsis\TARGET_CORTEX_M/core_cm7.h:1844:0:
note: this is the location of the previous definition
#define NVIC_USER_IRQ_OFFSET          16
mbed\cmsis\TARGET_CORTEX_M/core_cm7.h:1840:39: error: redefinition of '__NVIC_SetVector'
#define NVIC_SetVector              __NVIC_SetVector
C:\Users\johannes\.platformio\lib\cmsis-core_ID1237\source\cmsis_nvic.c:40:6: note: in expansion of macro
'NVIC_SetVector'
my platformio.ini file is as follows:
[env:disco_f746ng]
platform = ststm32
board = disco_f746ng
framework = mbed
lib_archive = true
lib_compat_mode = strict
lib_deps = BSP_DISCO_F746NG, LCD_DISCO_F746NG, TS_DISCO_F746NG
It does not make any sense why building 3 distinct libraries could create such a fuss. the Header definitions should not matter as far as I understood it because plattformio builds each lib separately and links the archives into the elf file. isn’t that correct? did I miss something?
All three dependencies depend on cmsis and because of that I’ve got a ton of redefinitions.
How can I prevent this from happening with the help of the platformIO system?
There must be a switch to prevent this. I just have not yet discovered in the docs yet.
I am happy for any help in this regard
I found a solution to this “redefinition” problem.
I added
  lib_ldf_mode = off
into my platformio.ini and all problems disappeared. I have found this in the docs:
https://docs.platformio.org/en/latest/librarymanager/ldf.html#ldf-mode
