I’m trying to use esp32 OTA and I’m getting a reboot when uploading. It says ELF file "SHA256: 0000000000000000". When I googled this I got discussions about this but they were all about the esp-idf platform and I’m using arduino. Also I didn’t understand those discussions because they were from platform developers.
Any ideas about what I’m doing wrong? My build output is …
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32cam.html
PLATFORM: Espressif 32 (3.2.0) > AI Thinker ESP32-CAM
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-openocd-esp32 2.1000.20201202 (10.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 28 compatible libraries
|-- <ArduinoOTA> 1.0
| |-- <Update> 1.0
| |-- <WiFi> 1.0
| |-- <ESPmDNS> 1.0
| | |-- <WiFi> 1.0
|-- <WiFi> 1.0
Retrieving maximum program size .pio\build\esp32cam\firmware.elf
Checking size .pio\build\esp32cam\firmware.elf
RAM: [== ] 16.9% (used 55216 bytes from 327680 bytes)
Flash: [== ] 22.7% (used 937946 bytes from 4128768 bytes)
and the esp32 console output is …
Start updating sketch
Progress: 0%
ELF file SHA256: 0000000000000000
Backtrace: 0x4008e2e4:0x3ffb1e10 0x4008e55d:0x3ffb1e30 0x40149a51:0x3ffb1e50 0x4008b6ba:0x3ffb1e70 0x401498f2:0x3ffb1e90 0x400d3361:0x3ffb1eb0 0x4014c740:0x3ffb1ed0 0x4014c949:0x3ffb1ef0 0x400d3191:0x3ffb1f10 0x400d3322:0x3ffb1f70 0x400d1570:0x3ffb1f90 0x400d4d7d:0x3ffb1fb0 0x400901ee:0x3ffb1fd0
