Since I installed a Wifi library that clashed and melted my existing installation, I am doing a reinstall of PlatformIO and the arduino-pico framework.
Does anybody recognise this error and have a fix or workaround? fatal: Failed to recurse into submodule path 'pico-sdk/lib/tinyusb'
I also have a project for the Pico RP2040 which is failing.
I have the latest version of Git installed.
Here is my platformio.ini that worked before I started the reinstall.
Here is the build output which is where the arduino-pico framwork is being installed. It is downloading parts of the pico-sdk:
Submodule path 'pico-sdk/lib/tinyusb/hw/mcu/ti': checked out '143ed6cc20a7615d042b03b21e070197d473e6e5'
error: unable to create file Application/8_uarts_server/RT-Thread/uart_server_rtt/rt-thread/components/vmm/linux_patch-v3.8/0001-RTT-VMM-implement-dual-system-running-on-realview-pb.patch: Filename too long
error: unable to create file Application/8_uarts_server/RT-Thread/uart_server_rtt/rt-thread/components/vmm/linux_patch-v3.8/0002-arm-gic-correct-the-cpu-map-on-gic_raise_softirq-for.patch: Filename too long
fatal: Unable to checkout '17761f5cf9dbbf2dcf665b7c04934188add20082' in submodule path 'pico-sdk/lib/tinyusb/hw/mcu/wch/ch32v307'
Submodule path 'pico-sdk/lib/tinyusb/lib/CMSIS_5': checked out '20285262657d1b482d132d20d755c8c330d55c1f'
Submodule path 'pico-sdk/lib/tinyusb/lib/FreeRTOS-Kernel': checked out '2a604f4a2818b8354b5e1a39e388eb5e16cfbc1f'
Submodule path 'pico-sdk/lib/tinyusb/lib/lwip': checked out '159e31b689577dbf69cf0683bbaffbd71fa5ee10'
Submodule path 'pico-sdk/lib/tinyusb/lib/sct_neopixel': checked out 'e73e04ca63495672d955f9268e003cffe168fcd8'
Submodule path 'pico-sdk/lib/tinyusb/tools/uf2': checked out '19615407727073e36d81bf239c52108ba92e7660'
Submodule 'hidapi' (https://github.com/signal11/hidapi) registered for path 'pico-sdk/lib/tinyusb/tools/uf2/hidapi'
Cloning into 'C:/Users/jimem/.platformio/.cache/tmp/pkg-installing-5v0888hr/pico-sdk/lib/tinyusb/tools/uf2/hidapi'...
Submodule path 'pico-sdk/lib/tinyusb/tools/uf2/hidapi': checked out 'a6a622ffb680c55da0de787ff93b80280498330f'
fatal: Failed to recurse into submodule path 'pico-sdk'
Submodule path 'tools/libbearssl/bearssl': checked out 'f294aa022f82833941ffdf3b0f306c2072e3a26c'
Submodule path 'tools/pyserial': checked out '0e7634747568547b8a7f9fd0c48ed74f16af4b23'
Error: VCS: Could not process command ['git', 'clone', '--recursive', 'https://github.com/earlephilhower/arduino-pico.git', 'C:\\Users\\jimem\\.platformio\\.cache\\tmp\\pkg-installing-5v0888hr']
Does anybody recognise these errors and have a fix or workaround?
