I’ve downloaded and ran blink_picow.uf2, and my pico LED does blink, I’ve got the raspberry pi pico to show up on COM ports by using Zadig (installing drivers) however on Arduino IDE and Platform IO, the default blink code complies fine but always returns exit status 1.
CONFIGURATION: Redirecting...
PLATFORM: Raspberry Pi RP2040 (1.12.0) > Raspberry Pi Pico
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
- framework-arduino-mbed @ 4.1.1
- tool-openocd-raspberrypi @ 2.1100.0 (11.0)
- tool-rp2040tools @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 42 compatible libraries
Scanning dependencies…
Checking size .pio/build/pico/firmware.elf
RAM: [== ] 15.1% (used 40752 bytes from 270336 bytes)
Flash: [ ] 0.2% (used 4034 bytes from 2097152 bytes)
Configuring upload protocol…
AVAILABLE: cmsis-dap, jlink, picotool, raspberrypi-swd
CURRENT: upload_protocol = picotool
Looking for upload port…
Auto-detected: /dev/cu.Bluetooth-Incoming-Port
Forcing reset using 1200bps open/close on port /dev/cu.Bluetooth-Incoming-Port
Uploading .pio/build/pico/firmware.elf
rp2040load 1.0.1 - compiled with go1.15.8
*** [upload] Error 1
I’ve used between mac and windows with the same problem
