So for some context I have been able to upload a simple blink program to the board from my mac as a test to see if the board was the problem. The upload worked without a hitch which leads me to believe it has to do with the environment and not PIO or the board. Has anyone else experienced this error. There is no obvious fault here in the output just that it always fails right after compiling. If I drag the resulting uf2 file into the pico it works as expected. Not sure how I should go about this…
System Specs:
Windows 11
Newest Version of VSCode (new computer everything is completely up to date)
Raspberry Pi Pico
Here is the output:
Processing pico (platform: raspberrypi; board: pico; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/pico.html
PLATFORM: Raspberry Pi RP2040 (1.7.0) > Raspberry Pi Pico
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
- framework-arduino-mbed @ 3.1.1
- tool-openocd-raspberrypi @ 2.1100.0 (11.0)
- tool-rp2040tools @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 37 compatible libraries
Checking size .pio\build\pico\firmware.elf
RAM: [== ] 15.1% (used 40696 bytes from 270336 bytes)
Flash: [ ] 0.2% (used 4034 bytes from 2097152 bytes)
AVAILABLE: cmsis-dap, jlink, picotool, raspberrypi-swd
CURRENT: upload_protocol = picotool
Looking for upload port...
Auto-detected: COM3
Forcing reset using 1200bps open/close on port COM3
Uploading .pio\build\pico\firmware.elf
rp2040load 1.0.1 - compiled with go1.15.8
*** [upload] Error 1
====================================================== [FAILED] Took 15.23 seconds ======================================================
* The terminal process "C:\Users\bickf\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
