Raspberry pi pico can't debug
I use “wizio-pico” configuration.
Can upload firmware to pico, but click debug, nothing happens。
I had the same problem with dacoolinus。(https://github.com/Wiz-IO/wizio-pico/issues/119)
[env:raspberry-pi-pico]
platform = wizio-pico
board = raspberry-pi-pico
framework = baremetal
build_type = debug
upload_protocol = picoprobe
debug_tool = picoprobe
This is my “platformio.ini”
Can someone help me, thanks a lot
You follow the instructions https://github.com/Wiz-IO/wizio-pico/wiki/DEBUG#picoprobe?
What text is appearing the “Debug Console” tab in VSCode?
I press and hold “BOOTSEL”, plug in the USB cable, and upload the firmware. But uploading the firmware again nothing happens. I can only unplug the USB cable again and repeat the previous operation.
This is my device manager.
I follow“ https://github.com/Wiz-IO/wizio-pico/wiki/DEBUG#picoprobe ”Operation,Nothing will change
You still didn’t answer my question on what output appears in the “Debug Console”.
Also, open a terminal and dp
git clone https://github.com/Wiz-IO/tool-pico-openocd
cd tool-pico-openocd
windows\picoprobe.exe -s share\openocd\scripts -f interface/picoprobe.cfg -f target/rp2040.cfg
What is the output?
Click the debug button, nothing
I can’t read chinese but I mean the “DEBUG CONSOLE” tab in VSCode. Even if it’s empty that’s good information
Yes, he is empty. Only compile information, click debug, nothing prints
Then please do as instructed here.
After I uploaded the firmware, my device manager could not find the PICO device.
C:\Users\17299>git clone GitHub - Wiz-IO/tool-pico-openocd: Raspberry Pi RP2040 OpenOCD
Cloning into ‘tool-pico-openocd’…
remote: Enumerating objects: 130, done.
remote: Counting objects: 100% (10/10), done.
remote: Compressing objects: 100% (10/10), done.
remote: Total 130 (delta 1), reused 3 (delta 0), pack-reused 120
Receiving objects: 100% (130/130), 14.72 MiB | 10.24 MiB/s, done.
Resolving deltas: 100% (40/40), done.
C:\Users\17299>cd tool-pico-openocd
C:\Users\17299\tool-pico-openocd>windows\picoprobe.exe -s share\openocd\scripts -f interface/picoprobe.cfg -f target/rp2040.cfg
Open On-Chip Debugger 0.10.0+dev-g14c0d0d-dirty (2021-01-27-15:43)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
Info : only one transport option; autoselect ‘swd’
adapter speed: 5000 kHz
Info : Hardware thread awareness created
Info : RP2040 Flash Bank Command
Error: Failed to open or find the device
Error: Can’t find a picoprobe device! Please check device connections and permissions.
So you did flash one Pico the picoprobe.uf2 firmware and changed the driver for “Picoprobe (Interface 2)” to WinUSB using Zadig? Because if yes, it should work.
grafik
C:\Users\Max\temp\tool-pico-openocd>windows\picoprobe.exe -s share\openocd\scripts -f interface/picoprobe.cfg -f target/rp2040.cfg
Info : only one transport option; autoselect 'swd'
Info : clock speed 5000 kHz
Info : SWD DPIDR 0x0bc12477
Info : SWD DLPIDR 0x00000001
Info : SWD DLPIDR 0x10000001
Info : rp2040.core0: hardware has 4 breakpoints, 2 watchpoints
Info : rp2040.core1: hardware has 4 breakpoints, 2 watchpoints
Info : starting gdb server for rp2040.core0 on 3333
shutdown command invoked
No picoprobe device
Why is there a CMSIS-DAP debugger? You’re supposed to be uploading tool-pico-openocd/picoprobe.uf2 at main · Wiz-IO/tool-pico-openocd · GitHub to your the Pico that you want to be your Picoprobe, that one doesn’t expose a CMSIS-DAP debugger.
:joy:
Do you mean that I need to upload picoprobe.uf2 with CMSIS-DAP to appear picoprobe device
No.
  1. You have two Raspberry Pi Picos. One of them you designate to be the Picoprobe, the other one to run your firmware.
  2. You disconnect all cables between them (USB, jumper cables).
  3. You take the Pico that is supposed to become the Picoprobe, hold down the BOOTSEL button and plug it into your computer via USB.
  4. The bootdrive should appear.
  5. You drag and drop the picoprobe.uf2 file into the bootdrive.
  6. The Pico is now programmed to be the Picoprobe and should automatically reboot.
  7. You should now see “Picoprobe (Interface 2)” as a device in Zadig.
  8. Change the driver to WinUSB.
  9. Rerun the windows\picoprobe.exe -s share\openocd\scripts -f interface/picoprobe.cfg -f target/rp2040.cfg command with still only the Picoprobe plugged. It should now not say "Error: Can’t find a picoprobe device! " anymore, but should complain that it cannot find a chip connected to the Picoprobe. Is that correct?
:joy:
I always thought it would be done with one PICO.
OK, I see. Thanks for your answer, I started to try.Good night.
Picoprobe involves 2 Picos: One is the debugging probe, one is the board getting debugged.
https://arduino-pico.readthedocs.io/en/latest/platformio.html#debugging
Yes. I didn’t read these documents, and many problems occurred because of ignoring these documents. Thank you so much
Sorry to bother you again. My pico still can’t debug.
Processing raspberry-pi-pico (platform: wizio-pico; board: raspberry-pi-pico; framework: baremetal)
-------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
<<<<<<<<<<<< WIZIO - RASPBERRY PI PICO ( PICOPROBE ) 2021 Georgi Angelov >>>>>>>>>>>>
[PIO-ASM] File ( encoder.pio.h ) exist
CONFIGURATION: https://docs.platformio.org/page/boards/wizio-pico/raspberry-pi-pico.html
PLATFORM: WizIO - Raspberry Pi Pico (1.1.1+sha.6d2fe69) > WizIO - Raspberry Pi Pico ( PICOPROBE )
HARDWARE: RP2040 125MHz, 256KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, picoprobe)
 - framework-wizio-pico @ 1.1.1+sha.60881de
 - tool-wizio-pico @ 1.0.0+sha.3a504e1
 - toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
SDK RASPBERRYPI PI PICO RP2040 ( PICO - SDK )
  * OPTIMIZATION : -Os
  * STACK        : 2048
  * HEAP         : 2048
  * SPECS        : nano.specs
  * WIFI         : NO
  * BINARY TYPE  : default ['w25q080', 'memmap_default.ld', '0x10000000']
Found 8 compatible libraries
Building in debug mode
DONE
Checking size .pio\build\raspberry-pi-pico\APPLICATION.elf
RAM:   [=         ]   7.7% (used 20196 bytes from 262144 bytes)
Flash: [=         ]   6.8% (used 142208 bytes from 2097152 bytes)
AVAILABLE: cmsis-dap, picoprobe, uf2
CURRENT: upload_protocol = picoprobe
Uploading...
  Converting to UF2 ( 0x10000000 )
  Wrote 284672 bytes to C:/Users/17299/Documents/PlatformIO/Projects/raspberryPico_GRBL_MPG_DRO/.pio/build/raspberry-pi-pico\APPLICATION.uf2
   Pico USB drive not found.
========================================================== [SUCCESS] Took 2.42 seconds ==========================================================
