What would be the best way to get RadioHead to compile using platformio on linux? There is a little script include the right headers, but this does not translate well to platformio.
Thanks, that’s where I started with, but there is code specific for arduino and code that is not. He uses a simulator.h and simMain.cpp to simulate arduino functions for Native. But some files are completely incompatible with native, like device driver libraries. It needs some kind of distinction between what files to include for native and for arduino. I ended up just making a version for native containing all the files in the root library folder and removing incompatible libraries and including simulator.h for native files.
Is that source filter also applied when using it as a library, say I have a .git repo and including it as a lib_dep ? Or only the project platformio.ini? For libraries that’s completely done in library.json?
