I’m not sure if this is the correct area for this post, so please let me know if not.
I am currently debugging a large Arduino Due sketch which has many interrupts. I am using a Segger J-Link w/ the JTAG protocol.
There is a point where I am detaching interrupts from several pins, and using a serial print immediately after to update an external application. While debugging, the serial print breaks after these interrupt detaches only sending a portion of the serial print message. In normal operation the serial print sends the entire message.
It looks something like this:
detach interrupt 1
detach interrupt 2
detach interrupt 3
Under normal operation “message” is received. Under debug operation it varies, but includes just portions of “message,” sometimes the beginning, or the middle, or the end.
Any insight or advice would be appreciated.
