I have some problems when uploading code for AVR via PyUPDI. The upload button is not working, I get some errors:
Processing ATmega808 (platform: atmelmegaavr; board: ATmega808;
framework: )
----------------------------------------------------------------Verbose
mode can be enabled via `-v, --verbose` option
CONFIGURATION:
https://docs.platformio.org/page/boards/atmelmegaavr/ATmega808.html
PLATFORM: Atmel megaAVR (1.5.0) > ATmega808
HARDWARE: ATMEGA808 16MHz, 1KB RAM, 8KB Flash
- tool-avrdude-megaavr 1.60300.191015 (6.3.0)
LDF: Library Dependency Finder ->
Found 0 compatible libraries
Checking size .pio\build\ATmega808\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project
Inspect"
RAM: [ ] 0.0% (used 0 bytes from 1024 bytes)
Flash: [ ] 1.5% (used 124 bytes from 8192 bytes)
AVAILABLE: jtag2updi
CURRENT: upload_protocol = jtag2updi
Looking for upload port...
Auto-detected: COM3
Forcing reset using 1200bps open/close on port COM3
Uploading .pio\build\ATmega808\firmware.hex
File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\Scripts\pyupd
i-script.py", line 33, in <module>
sys.exit(load_entry_point('pyupdi==0.0.0', 'console_scripts',
'pyupdi')())
i-script.py", line 25, in importlib_load_entry_point
return next(matches).load()
File "C:\Users\gigauser\.platformio\python3\lib\importlib\metadata.py", line
77, in load
module = import_module(match.group('module'))
File "C:\Users\gigauser\.platformio\python3\lib\importlib\__init__.py", line
127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in
_find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in
exec_module
File "<frozen importlib._bootstrap>", line 241, in
_call_with_frames_removed
File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack
ages\updi\__init__.py", line 1, in <module>
from .pyupdi import _main
ages\updi\pyupdi.py", line 11, in <module>
from updi.nvm import UpdiNvmProgrammer
ages\updi\nvm.py", line 6, in <module>
from updi.application import UpdiApplication
ages\updi\application.py", line 7, in <module>
from updi.link import UpdiDatalink
ages\updi\link.py", line 7, in <module>
from updi.physical import UpdiPhysical
ages\updi\physical.py", line 6, in <module>
import serial
File "C:\Users\gigauser\.platformio\penv\lib\site-packages\serial\__init__.py
", line 29, in <module>
from serial.serialwin32 import Serial
File "C:\Users\gigauser\.platformio\penv\lib\site-packages\serial\serialwin32
.py", line 15, in <module>
import ctypes
File "C:\Users\gigauser\.platformio\python3\lib\ctypes\__init__.py",
line 8, in <module>
from _ctypes import Union, Structure, Array
ImportError: DLL load failed while importing _ctypes: The specified
module could not be found.
*** [upload] Error 1
================== [FAILED] Took 2.24 seconds
==================The terminal process
"C:\Users\gigauser\.platformio\penv\Scripts\platformio.exe 'run',
'--target', 'upload', '--environment', 'ATmega808'" terminated with exit
code: 1.
If I call PyUPDI as command line, everything works well:
pyupdi -d mega808 -c COM3 -b 115200 -f .pio/build/ATmega808/firmware.hex
Device info: {'family': 'megaAVR', 'nvm': 'P:0', 'ocd': 'D:1', 'osc':
'3', 'device_id': '1E9326', 'device_rev': '0.0'}
Programming successful
My platfomio.ini looks like this:
[env:ATmega808]
platform = atmelmegaavr
board = ATmega808
framework =
upload_speed = 115200
upload_flags =
-d
mega808
-c
$UPLOAD_PORT
-b
$UPLOAD_SPEED
upload_command = pyupdi $UPLOAD_FLAGS -f $SOURCE
Any ideas how to solve the Upload-Button problem?
Thanks!
