I am using PlatformIO VSCode Extension on Windows 10 to build my project. I am currently trying to debug my project due to an unexpected null pointer dereference/memory corruption using GDBStub. However I keep getting a ParseException error with the message “Expected end of text (at char 0)”.
Here is the traceback:
Compiling .pio\build\client\bootloader\esp_hw_support\port\esp32\rtc_pm.c.o
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\entity.py", line 163, in _get_infos_from_file
results = parser.parseString(info.content, parseAll=True)
File "%USER%\.platformio\penv\.espidf-4.4.7\Lib\site-packages\pyparsing.py", line 1814, in parseString
raise exc
File "%USER%\.platformio\penv\.espidf-4.4.7\Lib\site-packages\pyparsing.py", line 1808, in parseString
se._parse( instring, loc )
File "%USER%\.platformio\penv\.espidf-4.4.7\Lib\site-packages\pyparsing.py", line 1548, in _parseNoCache
loc,tokens = self.parseImpl( instring, preloc, doActions )
File "%USER%\.platformio\penv\.espidf-4.4.7\Lib\site-packages\pyparsing.py", line 3722, in parseImpl
loc, exprtokens = e._parse( instring, loc, doActions )
File "%USER%\.platformio\penv\.espidf-4.4.7\Lib\site-packages\pyparsing.py", line 1552, in _parseNoCache
File "%USER%\.platformio\penv\.espidf-4.4.7\Lib\site-packages\pyparsing.py", line 3502, in parseImpl
raise ParseException(instring, loc, self.errmsg, self)
pyparsing.ParseException: Expected end of text (at char 163098), (line:2551, col:50)
During handling of the above exception, another exception occurred:
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\ldgen.py", line 178, in <module>
main()
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\ldgen.py", line 154, in main
mapping_rules = generation_model.generate(sections_infos)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\generation.py", line 520, in generate
root_node.insert(entity, sections, target, flags, entities)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\generation.py", line 251, in insert
self.child_placement(entity, sections, target, flags, sections_db)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\generation.py", line 243, in child_placement
child.insert(entity, sections, target, flags, sections_db)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\generation.py", line 304, in child_placement
found_sections = sections_db.get_sections(self.parent.name, self.name)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\entity.py", line 206, in get_sections
obj = self._match_obj(archive, obj)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\entity.py", line 194, in _match_obj
objs = self.get_objects(archive)
^^^^^^^^^^^^^^^^^^^Compiling .pio\build\client\bootloader\esp_hw_support\port\esp32\rtc_sleep.c.o
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\entity.py", line 187, in get_objects
self._process_archive(archive)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\entity.py", line 175, in _process_archive
parsed = self._get_infos_from_file(stored)
File "%USER%\.platformio\packages\framework-espidf\tools\ldgen\entity.py", line 165, in _get_infos_from_file
raise ParseException('Unable to parse section info file ' + info.filename + '. ' + p.msg)
pyparsing.ParseException: Unable to parse section info file %PROJECT%/.pio/build/client/esp-idf/esp_event/libesp_event.a. Expected end of text (at char 0), (line:1, col:1)
*** [.pio\build\client\sections.ld] Error 1 ***
Here are my packages:
Resolving server dependencies...
Platform espressif32 @ 6.9.0 (required: espressif32)
├── framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b (required: platformio/framework-arduinoespressif32 @ ~3.20017.0)
├── framework-espidf @ 3.40407.240606 (required: platformio/framework-espidf @ ~3.40407.0)
├── tool-cmake @ 3.16.4 (required: platformio/tool-cmake @ ~3.16.0)
├── tool-esptoolpy @ 1.40501.0 (required: platformio/tool-esptoolpy @ ~1.40501.0)
├── tool-idf @ 1.0.1 (required: platformio/tool-idf @ ~1.0.1)
├── tool-mconf @ 1.4060000.20190628 (required: platformio/tool-mconf @ ~1.4060000.0)
├── tool-ninja @ 1.9.0 (required: platformio/tool-ninja @ ^1.7.0)
├── toolchain-esp32ulp @ 1.23800.240113 (required: platformio/toolchain-esp32ulp @ ~1.23800.0)
└── toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5 (required: espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5)
Resolving client dependencies...
platform.ini:
platform = espressif32`
board = esp32doit-devkit-v1
monitor_raw = yes
framework = arduino, espidf
-DCORE_DEBUG_LEVEL=3
-DCONFIG_ESP_SYSTEM_PANIC_HALT=y
-DCONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID=y
-DCONFIG_ESP_SYSTEM_GDBSTUB_RUNTIME=y
debug_build_flags =
-Os
-g
-ggdb3
-DCONFIG_ESP_COREDUMP_DECODE_INFO=y
[env:server]
debug_extra_cmds =
break main
break recv_callback
break send_callback
break notify_client
board_build.cmake_extra_args =
-DCURRENT_ENV=SERVER
[env:client]
debug_extra_cmds =
break listen_table
break listen_goal
break send_packet
break recv_callback
break send_callback
-DCURRENT_ENV=CLIENT
I tried reinstalling the PlatformIO core by deleting the .platformio folder and the .pio folder and reinstalling the PlatformIO extension, and also reinstalling all the PlatformIO packages using pio pkg uninstall and reinstalling but nothing worked. Building the project normally works fine albeit with some warnings. Any help would be appreciated.
