Summary
This text will be hidden
The PlatformIO board listing is formatted for each platform group by a Python pretty-print library. The fields do not align if pasted into a file and it is not structured like CSV or Json for computer input. A speadsheet view might be optionally desirable so I provide a Lua script to do that.
-- file: make_csv.lua
-- RMM; 2022.apr.17
From PlatformIO boards.txt to boards.csv for spreadsheet view..
The pio "boards" listing is not intended to be processed by a program.
This Lua script fixes the irregular text format and outputs CSV.
Usage:
1. pio boards > btmp.txt
2. Lua make_csv.lua
3. Open boards.csv in a spreadsheet
local filename1 = "btmp.txt" -- capture of "pio boards > btmp.txt"
local filename2 = "boards.csv" -- output board list in CSV format
local header = "ID, MCU, Freq, Flash, RAM, Platform, Remarks\n"
local num_out = 0
local line1 = ""
local strPlatform = ""
local numPlatforms = 0
local infile = assert(io.open(filename1, "r"))
local outfile = io.open(filename2,"w");
outfile:write(header)
num_out = num_out+1
local function parse_line(s1)
-- skip lines malformed or not having MCU properties
if not s1 then return end
local x = string.sub(s1, 1,1)
if x == '-' then return end
if x == '=' then return end
if string.sub(s1,1,2) == "ID" then return end
if string.sub(s1,1,8) == "Platform" then
strPlatform = string.sub(s1,10)
numPlatforms = numPlatforms + 1
return
end
-- capture the MCU properties from columns 1-5, skip spaces
-- capture all the characters in the "name" column
local a1,a2,a3,a4,a5,a6 = string.match( s1,
"(%g+)%s* (%g+)%s* (%g+)%s* (%g+)%s* (%g+)%s* (.*)")
if a6 then
-- commas are invalid within a data field
a6 = string.gsub(a6, ",", "_" )
end
local tmp = string.format("%s, %s, %s, %s, %s, %s, %s",
a1,a2,a3,a4,a5,strPlatform,a6)
if not a1 then return end
-- the Bonfires have no MCU field
if a1 == "bonfire-basic-dram" then return end
if a1 == "arty-axi-dram" then return end
-- print the CSV line and write it to the result file
print(tmp);
outfile:write(tmp .. "\n")
num_out = num_out+1
return
end -- function parse_line()
---------------- main loop -------------------
while true do
line1 = infile:read()
if not line1 then break end
if type(line1) == "string" then
parse_line(line1)
end
end
print("Lines out=", num_out)
print("Number Platforms =", numPlatforms)
infile:close()
outfile:close()
-- end make_csv.lua
Summary
