Proper way to fix library compilation errors
Hello - I’m new to the PlatformIO user community. Recently I tried to compile code that uses the FastLED library on a XIAO-ESP32C6 processor and the compiler flagged a number of errors. While the errors seem easy to correct, I’m not sure how I should make the corrections. I’m concerned that if I correct he version of the library on my system my corrections may be overwritten by a future update to the library. I’d appreciate advice on dealing with this matter. - Thanks! - Jim
Can you share your platformio.ini and minimal code to reproduce the errors?
I’m happy to share the various logs though it will be later today as I’m at work now. Thanks!
Hello MaxGerhardt - For reasons I cannot explain, I’m now able to build code with the FastLED library. But since you were kind enough to offer to help me, and since you requested I post my platformio.ini file contents, I’ve posted the contents of my platformio.ini file below:
[env:seeed-xiao-esp32-c6]
platform = Seeed Studio
board = seeed-xiao-esp32-c6
lib_deps = fastled/FastLED@^3.10.3
