I have created a Project for nRF52_dk using Arduino Framework. I’m try to use FFT supported by the CM4 on this device.
Every time i’m got a linker error: undefined reference to `arm_cfft_radix4_init_f32’
What I’m missing ? or how i do it correctly? Please Help
It should be a part of the sdk im think. Im including the arm_math.h. The Funktion is declared in this header file.
After some research. This are parts of the arm dsp package. I dont found the Implementation.
compile the CMSIS-DSP library from the source files (here)
tell the linker to link against the statically compiled library
I’ll do the latter because it’s easier. The libraries are compiler per Cortex flavour, so you have the Cortex-M3, M4, M4F (M4 + FPU) etc. Your nrf52_dk board has a nRF52832 which is in turn a "The ARM® Cortex®-M4 processor with floating-point unit (FPU) " (here, here), i.e. an M4F. However, PlatformIO compiles the firmware using soft-float instead of hard-float (-mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16, here), which means we actually have to use the link-compatible M4 type. See here for an explanation on float-ABIs.
Hello Maxgerhard, sorry that i’m comback to this issue.
But after successfully compiling the Project, i run into another issue.
After copy the elf over to the nrf52_dk, this is not running.
I have try to do some Serial.print and digital write for toggle the OnBoard led in the Setup method. but Nothing happens. So i guess that something is wrong with the linked Code.
I have updated the Project on GitHub to Show you what i have done. Do you have any idea ?
Did you do the negative test? I.e., remove all references to arm_math.h and don’t link against the library, just do a basic Serial.begin() and print. Does that show up?
