Project compiles, but won't work if I add a param in a subclass constructor
Hi. I’m having a very specific issue, and really obscure as well. If I add a second param to a subclass, program compiles and uploads to NodeMCU ESP32, but it doesn’t work properly.
Basically, I have a set of animations for an Adafruit Ring, and I’m using FastLed to create them.
I’m working with platformio v5.0.2b1, using CLion 20.04, and the toolchain for Clion is MinGW.
Anyway, the issue I’m about to tell you occurs even if I compile using Arduino IDE.
Basically, animations are polymorphic, and I’m kinda using the Strategy pattern to pass the animations to the led ring object I created.
Code structure is quite simple. Apart from the strategy pattern I’m using Adapter to wrap and decouple Fastled.
You can see the code structure here. It’s working, but not using Leds (only strings):
https://repl.it/repls/MeagerPrivateBoard#main.cpp
So problem is: whenever I add a second parameter to the constructor of a given animation (meaning, to a subclass of Animation class), the program compiles, but the animation stops working. Ring stays off (no lights at all)
FYC:
#pragma once
#include <FastLED.h>
#include "Animation.h"
#include "Ring.h"
class PlainColorAnimation : public Animation {
public:
    PlainColorAnimation(Ring &aRing)
            : Animation(aRing) {}
    void execute() override {
        ring.fill(Ring::colors["yellow"]); // TODO: make this dynamic by receiving a color param
Check now this. What I try to do, I try to add a second parameter (just like you can see in the working code I linked before). So:
PlainColorAnimation(Ring &aRing, CRGB aColor = CRGB::Green)
Just that, I’m not even setting aColor value to a member variable, and that param causes the animation to fail. Meaning, no lights will display, and… Serial console will display garbage (I think this may be important).
I wondered why the Repl example worked fine. It’s not a problem with polymorphism, is it? So, I discovered Repl uses c++17 and I had c++11. So…, I bumped my version adding some lines in my ini file.
FYC:
[esp32]
; upgrade XTensa32 GCC/G++ compiler to 8.2.0
; use bleeding edge arduino-esp32
platform_packages =
; toolchain-xtensa32 @ 2.80200.200226 ← this line here is maybe needed by fails in windows 10
framework-arduinoespressif32 @ GitHub - espressif/arduino-esp32: Arduino core for the ESP32
[common]
; do not redefine arduino
;    -DARDUINO=10800
    -DESP32=1
    -DARDUINO_ARCH_ESP32=1
    -DBOARD_HAS_PSRAM
    -std=c++17
; only use C++17 now not GNU++17. This is an either-or relation.
;    -std=gnu++17
build_unflags =
    -std=gnu++11
[env:nodemcu-32s]
platform = espressif32@1.12.4
board = nodemcu-32s
lib_deps = fastled/FastLED@^3.3.3
lib_ldf_mode = off
upload_port = COM5
platform_packages =
    ${esp32.platform_packages}
    ${common.build_flags}
build_unflags =
    ${common.build_unflags}
I’ve got that code from here:
Problem persist :frowning:
Any clue?
I don’t see any problems with the code or the execution on my ESP32. After copying all your files from the REPL example and changing the main.cpp to
#include <iostream>
using namespace std;
#include "animation.h"
#include "plainColorAnimation.h"
#include "rainbowAnimation.h"
#include "ring.h"
Ring ring{};
Animation* plainGreenColor = new PlainColorAnimation(ring, "green");
Animation* rainbow = new RainbowAnimation(ring);
Animation* plainBlueColor = new PlainColorAnimation(ring, "blue");
///////////////////// Test code
  Serial.println("Beginning of firmware!!");
  Serial.flush();
  ring.draw(plainGreenColor);
  std::cout << "\n";
  ring.draw(rainbow);
  std::cout << "\n";
  ring.draw(plainBlueColor);
void loop() { }
my ESP32 outputs on reset
- It's all green now!
0 green
1 green
2 green
3 green
4 green
5 green
6 green
7 green
8 green
9 green
10 green
11 green
12 green
13 green
14 green
15 green
16 green
17 green
18 green
19 green
20 green
21 green
22 green
23 green
- Rainbow, ujuuu!
0 blue
1 blue
2 blue
3 blue
4 blue
5 blue
6 blue
7 green
8 green
9 green
10 green
11 green
12 green
13 yellow
14 yellow
15 yellow
16 yellow
17 yellow
18 yellow
19 orange
20 orange
21 orange
22 orange
23 orange
- It's all blue now!
0 blue
1 blue
2 blue
3 blue
4 blue
5 blue
6 blue
7 blue
8 blue
9 blue
10 blue
11 blue
12 blue
13 blue
14 blue
15 blue
16 blue
17 blue
18 blue
19 blue
20 blue
21 blue
22 blue
23 blue
Which looks all good to and is also the same output in the REPL.
And that is with the constructor being
PlainColorAnimation(Ring& aRing, string aColor = "blue")
    : Animation(aRing), color(aColor) {};
already. If I change it to e.g.
  PlainColorAnimation(Ring& aRing, string aColor = "blue", int someOtherDefault=123)
I get the same exact output.
And that is all with the basic platformio.ini of
[env:esp32]
No fancy compiler overwrites, not using an outdated ESP32 platform version. Just the defaults, which work perfectly fine.
So I can only suggest to
  1. use the same platformio.ini and retry
  2. double check that your sketch implements setup() and loop() and not main() as in the desktop variant
  3. upload the exact PlatformIO project folder and code that has the problem.
Thanks a lot for trying the code and taking the time to test it in a real env.
I tried with you simple ini file
[env:nodemcu-32s]
I’m not sure about the board, but works fine
board = esp32dev instead of nodemcu-32s
And yes, I’m using Arduino framework and no any other. I have setup and run working properly.
I found the issue. It wasn’t as obscure as I thought! I just seems like I don’t know how to use dictionaries (?
So, this wasn’t working:
public:
    PlainColorAnimation(Ring &aRing, CRGB aColor = Ring::colors["green"])
        ring.fill(Ring::colors["blue"]); <-- this code from dictionary works fine, btw
private:
    CRGB color;
But changed the CRGB aColor = Ring::colors["green"] to CRGB::Yellow works now
Believe me I spended the entire day trying to make things works. I’m so not used to c++, I this one was bugging me a lot.
Thanks again for your feedback.
So, I’ll google and find out why this piece of code won’t work when used as param (but it does used in other contexts)
// .h
class Ring {
public:
    typedef std::map<std::string, CRGB> ColorMap;
    static ColorMap colors;
// .cpp
Ring::ColorMap Ring::colors = {
        {"blue",   CRGB::Blue},
        {"green",  CRGB::Green},
        {"red",    CRGB::Red},
        {"yellow", CRGB::Yellow},
