epikao
April 7, 2022, 3:08pm
1
Hello
I have a Usbasp programmer (from Aliexpress), and I want program my Attiny45 with that, but it does not work. I get the following error message:
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
my platformio configuration is following. What is wrong?
Thank you.
[env:attiny45]
board = attiny45
upload_protocol = usbasp
Do you see the device in the Windows device manager / lsusb?
epikao
April 7, 2022, 3:19pm
3
ah, so I must check first for the driver, thank you
epikao
April 7, 2022, 3:24pm
4
I installed the driver, now I have following messages. Where can I found a standard fuse configuration for attiny45?
Needs
upload_flags = -e
in the platformio.ini for an erase.
epikao
April 13, 2022, 6:59am
6
ok thank you, now I still have following errors:
my setting:
[env:attiny45]
board = attiny45
upload_flags = -e
Hm that doesn’t look good at all. Please use the project task Advanced → Verbose Upload and show the avrdude invocation line that is appearing there.
epikao
April 19, 2022, 1:54pm
8
Thank you, see below the avrdude messages with “Verbose Upload”:
epikao:
It complains about an old firmware, can you update per USBASP firmware update | bitbanging ?
epikao
April 22, 2022, 10:36pm
12
It still not works. I think there was a problem with updating the firmware:
epikao
April 24, 2022, 8:23pm
13
in addition:
When I upload with shorted JP3, then it is hanging at following position:
epikao
April 24, 2022, 8:27pm
14
I tried now my other USBasp and shorted JP3 and now it works… strange:
epikao
April 24, 2022, 8:30pm
15
so I think solution should be JP3 shorted and JP21 to +5V and not +3.3V…
I have a supplementary question:
How do I turn off the clock divider from 8? (my delay is 8 times too slow…), I have already tried the following but without success:
[env:attiny45]
board = attiny45
upload_flags = -e
board_fuses.lfuse = 0xE2
board_fuses.hfuse = 0xDF
board_fuses.efuse = 0xFF
Have you burned the new fuses using the project task Burn Fuses?
ok I see, did not know that with “Set Fuses” also the fuses are programmed. Thank you
