I have a strange problem, I’m using Atmega2560V with internal oscillator.
If I set the fuses (bootloader) to 4MHz internally and in platformio.ini I set the flag f_cpu= 4000000L.
On the serial (9600) I get some strange characters like
:�־���k␀��{H
�␏��␐�␀��␀�X
:�־���k␀��{X
kCgg␄�����������������������␆��k���␎���k␆kN��␏�␎�␎␐␆��k�
KJ
�␎���k␆kN��␏�␎�␎␔␆��k�!�␎���k␆kN��␏�␎�␎␔␆��k�␋KJ
�␎���k␆kN��␏�␎�␎␐␆o�����HF␐␂1!��␘1���␔␂1!��␘1���␔␂1!��␘1���␐␂1!��␘1���␐B�
If I set 8000000L on platformio.ini but keep 4MHz on Fuse, it works.
But if I set 8MHz on Fuse and keep 8000000L, serial monitor tells me:
avrdude error: programmer is not responding
avrdude warning: attempt 1 of 10: not in sync: resp=0x00
I tried to load a blink led sckatch from Arduino IDE at 8MHz and it works.
My platformio.ini fili is
[env:atmega2560]
board = ATmega2560
framework = arduinolib_deps = ---------
…board_hardware.bod = disabled
upload_speed = 9600
monitor_speed = 9600
board_build.f_cpu = 4000000L
board_hardware.oscillator = internal
upload_port = COM3
monitor_port = COM3
