Recently I have tried to improve my CI game and I fired up a pi with Jenkins and I am in the process of integrating my PIO project in jenkins.
I have finally managed to ensure my jenkins can build PIO projects just fine however I have reached a stump in my knowledge.
I have written a very simple test program where my own libraries are ordered in a common directory as such:
ESP8266Projects
|-- Common
| |-- WiFi
| |-- include
| |-- CWifi.h
| |-- IWifi.h
| |-- src
| |-- CWiFi.cpp
|-- RGBWLight
|-- src
|-- main.cpp
Now I have included this common folder (which will be for shared libaries) in my .ini file as such:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
lib_extra_dirs =
${PROJECT_DIR}/../Common
check_tool = cppcheck
check_flags = --enable=all
Now my problem is the following:
If I compile this program in VSCode (using PlatformIO) this works just fine. No problem.
I then commit it which forces Jenkins to checkout the code and compile it by also running pio -v it fails since now it says it can’t find IWiFi.h although it does say in the dependency graph it found the library… I have no clue as to why and could use some help.
Jenkins output:
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino; lib_extra_dirs: ${PROJECT_DIR}/…/Common; check_tool: cppcheck; check_flags: --enable=all)
CONFIGURATION:
PLATFORM: Espressif 8266 (2.6.3) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
LDF: Library Dependency Finder →
Found 30 compatible libraries
Scanning dependencies…
|-- (/var/lib/jenkins/workspace/ESP-Projects/Common/WiFi)
| |-- 1.0 (/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi)
xtensa-lx106-elf-g++ -o .pio/build/nodemcuv2/src/main.cpp.o -c -fno-rtti -std=c++11 -Os -mlongcalls -mtext-section-literals -falign-functions=4 -U__STRICT_ANSI__ -ffunction-sections -fdata-sections -fno-exceptions -Wall -DPLATFORMIO=50101 -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_NODEMCU -DF_CPU=80000000L -D__ets__ -DICACHE_FLASH -DARDUINO=10805 -DARDUINO_BOARD="PLATFORMIO_NODEMCUV2" -DFLASHMODE_DIO -DLWIP_OPEN_SRC -DNONOSDK22x_190703=1 -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DVTABLES_IN_FLASH -Isrc -I/var/lib/jenkins/workspace/ESP-Projects/Common/WiFi/include -I/var/lib/jenkins/workspace/ESP-Projects/Common/WiFi/src -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/libc/xtensa-lx106-elf/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/cores/esp8266 -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/lwip2/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/variants/nodemcu src/main.cpp
xtensa-lx106-elf-gcc -CC -E -P -DVTABLES_IN_FLASH /var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/ld/eagle.app.v6.common.ld.h -o .pio/build/nodemcuv2/ld/local.eagle.app.v6.common.ld
xtensa-lx106-elf-g++ -o .pio/build/nodemcuv2/lib7fb/ESP8266WiFi/BearSSLHelpers.cpp.o -c -fno-rtti -std=c++11 -Os -mlongcalls -mtext-section-literals -falign-functions=4 -U__STRICT_ANSI__ -ffunction-sections -fdata-sections -fno-exceptions -Wall -DPLATFORMIO=50101 -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_NODEMCU -DF_CPU=80000000L -D__ets__ -DICACHE_FLASH -DARDUINO=10805 -DARDUINO_BOARD="PLATFORMIO_NODEMCUV2" -DFLASHMODE_DIO -DLWIP_OPEN_SRC -DNONOSDK22x_190703=1 -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DVTABLES_IN_FLASH -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/libc/xtensa-lx106-elf/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/cores/esp8266 -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/lwip2/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/variants/nodemcu /var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp
xtensa-lx106-elf-g++ -o .pio/build/nodemcuv2/lib7fb/ESP8266WiFi/CertStoreBearSSL.cpp.o -c -fno-rtti -std=c++11 -Os -mlongcalls -mtext-section-literals -falign-functions=4 -U__STRICT_ANSI__ -ffunction-sections -fdata-sections -fno-exceptions -Wall -DPLATFORMIO=50101 -DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_NODEMCU -DF_CPU=80000000L -D__ets__ -DICACHE_FLASH -DARDUINO=10805 -DARDUINO_BOARD="PLATFORMIO_NODEMCUV2" -DFLASHMODE_DIO -DLWIP_OPEN_SRC -DNONOSDK22x_190703=1 -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DVTABLES_IN_FLASH -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/libc/xtensa-lx106-elf/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/cores/esp8266 -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/tools/sdk/lwip2/include -I/var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/variants/nodemcu /var/lib/jenkins/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/CertStoreBearSSL.cpp
src/main.cpp:2:19: fatal error: IWiFi.h: No such file or directory
- Looking for IWiFi.h dependency? Check our library registry!
- CLI > platformio lib search “header:IWiFi.h”
#include <IWiFi.h>
compilation terminated.
Thanks a bunch already!
