When designing software for ESP32, the module used Wi-Fi module LuaNode32 with ESP-32. Now I transfer the project to my board with ESP32-WROOM32. There was a problem - I can not write the code in ESP32.
Log:
Processing esp32dev (framework: arduino; platform: espressif32; board: esp32dev)
PLATFORM: Espressif 32 > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Collected 26 compatible libraries
|-- <WiFi> 1.0
|-- <Preferences> 1.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
|-- <FS> 1.0
Linking .pioenvs\esp32dev\firmware.elf
Retrieving maximum program size .pioenvs\esp32dev\firmware.elf
Checking size .pioenvs\esp32dev\firmware.elf
Building .pioenvs\esp32dev\firmware.bin
DATA: [= ] 11.8% (used 38712 bytes from 327680 bytes)
PROGRAM: [====== ] 56.3% (used 738518 bytes from 1310720 bytes)
esptool.py v2.6
AVAILABLE: esp-prog, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Use manually specified: COM3
Uploading .pioenvs\esp32dev\firmware.bin
esptool.py v2.6
Serial port COM3
Connecting.....
Chip is ESP32D0WDQ6 (revision 0)
Features: WiFi, BT, Dual Core, Coding Scheme None
MAC: 24:0a:c4:81:77:2c
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
Compressed 16176 bytes to 10658...
*** [upload] Error 2
A fatal error occurred: Timed out waiting for packet content
What to do?
