I’m trying to set up a new blinky project on with an ATmega328PB on a custom PCB. It runs with 5V and a 16MHz external oscillator. I’d like to initially burn the bootloader and the fuses with a JTAG ICE mkII in ISP mode and afterwards upload software using the serial interface. And I’d like to use the serial also for debugging with avr-stub.
My platformio.ini was initially from the minicore repo with some modifications from several threads and doc pages:
[platformio]
default_envs = Upload_UART ; Default build target
[env]
board = ATmega328PB
board_build.variant = pb-variant
board_build.f_cpu = 16000000L
board_hardware.bod = disabled
board_hardware.eesave = yes
board_hardware.oscillator = external
board_hardware.uart = uart0
build_unflags = -flto
; GDB stub implementation
jdolinay/avr-debugger @ ~1.4
debug_tool = avr-stub
debug_port = /dev/ttyUSB0
build_type = debug
build_flags = -DAVR8_BREAKPOINT_MODE=1
monitor_port = ${env:Upload_UART.upload_port}
monitor_speed = 57600
; pio run -e Upload_UART -t upload
[env:Upload_UART]
upload_protocol = urclock
upload_port = /dev/ttyUSB0
board_upload.speed = ${env:fuses_bootloader.board_bootloader.speed}
; pio run -e Upload_ISP -t upload
[env:Upload_ISP]
upload_protocol = custom
upload_flags =
-C$PROJECT_PACKAGES_DIR/tool-avrdude/avrdude.conf
-p$BOARD_MCU
-cjtag2isp
-D
; pio run -e fuses_bootloader -t fuses
; pio run -e fuses_bootloader -t bootloader
[env:fuses_bootloader]
board_bootloader.type = urboot ; urboot, optiboot or no_bootloader
board_bootloader.file = ~/.platformio/packages/framework-arduino-avr-minicore/bootloaders/urboot/atmega328pb/watchdog_1_s/autobaud/uart0_rxd0_txd1/no-led/urboot_atmega328pb_pr_ee_ce.hex
board_bootloader.speed = 115200 ; Bootloader baud rate
upload_flags =
-p$BOARD_MCU
-cjtag2isp
-v
Burning the bootloader and/or fuses doesn’t work at all from within PIO, so I do
./avrdude -p atmega328pb -C ~/.platformio/packages/tool-avrdude/avrdude.conf -cjtag2isp -Uflash:w:~/.platformio/packages/framework-arduino-avr-minicore/bootloaders/urboot/atmega328pb/watchdog_1_s/autobaud/uart0_rxd0_txd1/led+b5/urboot_atmega328pb_pr_ee_ce.hex:i -Ulock:w:0xFF:m
externally. After that I’m able to upload my program with the button (via Upload_UART). Upload_ISP also works but it seems to delete the bootloader and afterwards Upload_UART doesn’t work any more. So I have to repeat the external call.
Currently my program is only the following blinky example:
#include "avr8-stub.h"
#include "app_api.h" // only needed with flash breakpoints
void setup()
debug_init();
pinMode(PIN_PD3, OUTPUT);
pinMode(PIN_PD4, OUTPUT);
void loop()
// breakpoint();
digitalWrite(PIN_PD3, 1);
delay(1000);
digitalWrite(PIN_PD3, 0);
delay(1000);
digitalWrite(PIN_PD4, 1);
delay(1000);
digitalWrite(PIN_PD4, 0);
delay(1000);
When I try to debug it, the debug menu opens for a very short moment and then closes again. With breakpoint();
the LEDs blink as expected when I managed to flash the application (see above). When I uncomment breakpoint();
the LEDs don’t blink at all.
I think the platformio.ini is screwed, but I have no idea what’s wrong, because I’m new to PlatformIO and its mechanisms. What has to be changed to make things work?
EDIT:
Updated the platformio.ini above and added the following:
When I enter pio run -e fuses_bootloader -t bootloader
I get
Setting fuses
avrdude: Version 7.2-arduino.1
Copyright the AVRDUDE authors;
see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is /home/michael/.platformio/packages/tool-avrdude/avrdude.conf
User configuration file is /home/michael/.avrduderc
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : jtag2isp
avrdude: usbdev_open(): found JTAGICE mkII, serno: 00xxxxxxxxxx
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
for setting the fuses and that works. Directly afterwards it tries to burn the bootloader and then I get
Uploading bootloader
Using Port : usb
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2103)
avrdude main() error: unable to open programmer jtag2isp on port usb
avrdude done. Thank you.
Seems like the mkII is still in use at that time.
