I’m experimenting because I’m working through the author review part of the second edition of Arduino Software Internals, and the PlatformIO chapter has been updated.
I note that there is a --project-dir
or -d
option to pio init
. However, the operation is inconsitent.
In my first test, I didn’t create the output directory, and it failed, advising me that the output directory didn’t exist. I can cope with that, but it would be nice if it created the output as it creates the src
, lib
directories anyway, normally.
In my second test, I created the directory and specified it thus:
mkdir fred
pio init -b uno -d fred
That fell over with a lot of red text and Python errors—see below. However, it did create the usual directories and most of platformio.ini
—the comments were there but the [uno]
environment was missing.
I cleared out and tried again with a relative path.
rm -Rf fred
mkdir fred
pio init -b uno -d ./fred
Same problem, same messages, same output.
Finally, I tested with a full path:
rm -Rf fred
mkdir fred
pio init -b uno -d $PWD/fred
And this worked perfectly.
The output from the failing tests is:
The following files/directories have been created in fred
lib - Put project specific (private) libraries here
FileNotFoundError: Traceback (most recent call last):
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/platformio/__main__.py", line 103, in main
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1157, in __call__
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/platformio/cli.py", line 85, in invoke
return super().invoke(ctx)
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1688, in invoke
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1434, in invoke
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 783, in invoke
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/platformio/project/commands/init.py", line 92, in project_init_cmd
update_board_envs(project_dir, boards, project_options, env_prefix)
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/platformio/project/commands/init.py", line 336, in update_board_envs
config.save()
File "/home/norman/.platformio/penv/lib/python3.10/site-packages/platformio/project/config.py", line 551, in save
with open(path or self.path, mode="w+", encoding="utf8") as fp:
FileNotFoundError: [Errno 2] No such file or directory: 'fred/platformio.ini'
`python -m pip install -U platformio` command
The bit about “FileNotFoundError: [Errno 2] No such file or directory: ‘fred/platformio.ini’” seems misleading as it managed to create the file, although I suspect that’s more of a “copy and paste” operation. I suspect it’s trying to open the file to write the environment settings. I’m not a Python programmer but it looks to me like it can’t tell the difference between a full path or a relative one, and I find that hard to believe.
Cheers,
Norm.
