Problems with outdated libraries and unavailable/not working settings
I’m using VSCode and Platform.io to program an ESP32. I’ve found many problems regarding the current implementation of the BluetoothSerial.h library available in Pio, so i went into Espressif’s website to see how i could use a more modern distribution. As i’ve found, i’m supposed to include this line in my .ini file:
platform_packages =
    framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32#master
This, however, results in this errors:
KeyError: 'framework-arduinoespressif32-libs':
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 173:
  File "C:\Users\bruxx\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Script\SConscript.py", line 612:
  File "C:\Users\bruxx\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Script\SConscript.py", line 279:
  File "C:\Users\bruxx\.platformio\platforms\espressif32\builder\main.py", line 368:
  File "C:\Users\bruxx\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Util\envs.py", line 251:
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\builder\tools\piobuild.py", line 61:
    env.ProcessProgramDeps()
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\builder\tools\piobuild.py", line 121:
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\builder\tools\piobuild.py", line 347:
    SConscript(env.GetFrameworkScript(name), exports="env")
  File "C:\Users\bruxx\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Script\SConscript.py", line 676:
    return method(*args, **kw)
  File "C:\Users\bruxx\.platformio\platforms\espressif32\builder\frameworks\arduino.py", line 36:
    SConscript(
  File "C:\Users\bruxx\.platformio\packages\framework-arduinoespressif32@src-e36c2260a49b9bf6768237494cebb35d\tools\platformio-build.py", line 38:
    FRAMEWORK_LIBS_DIR = platform.get_package_dir("framework-arduinoespressif32-libs")
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 32:
    pkg = self.get_package(name)
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 29:
    return self.pm.get_package(spec or self.get_package_spec(name))
  File "C:\Users\bruxx\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 21:
    owner=self.packages[name].get("owner"),
========================== [FAILED] Took 0.94 seconds ==========================
As this is much important to my work, i need to know if i’m doing something wrong or this is a bug or whatever.
Thanks!
