I have this config
[platformio]
default_envs = esp32s3
; USB Flash
[env:esp32s3]
board = esp32-s3-devkitc-1-n16r8v
board_build.flash_mode = qio
board_build.psram_type = opi
board_build.psram = opi
board_build.arduino.memory_type = qio_opi
board_build.f_flash = 80000000L
board_build.partitions = default_16MB.csv
board_upload.flash_size = 16MB
board_upload.usb_mode = cdc_jtag
upload_protocol = esptool
upload_port = COM23
upload_speed = 460800
monitor_port = COM16
monitor_echo = yes
monitor_filters = esp32_exception_decoder, time, colorize
-I src
-I src/ui
-I include
-D LV_CONF_INCLUDE_SIMPLE
-D ARDUINO_USB_CDC_ON_BOOT=1
-D ARDUINO_USB_MODE=1
-D BOARD_HAS_PSRAM
-D CORE_DEBUG_LEVEL=0
-D sOpenMeteoString=\"http://api.open-meteo.com/v1/forecast?latitude=50.66&longitude=7.8228&hourly=temperature_2m&timezone=Europe%%2FBerlin\"
-D ScreenWidth=480
-D ScreenHeight=320
-D DRAW_BUF_SIZE=30700
-D SCREEN_COUNT=13
-D SDA_1=8
-D SCL_1=9
-D AkkuReadGPIO1=25
-D bWokWi_WiFi=false
-D DHTPIN=5
-D DHTTYPE=DHT21
-D I2CFrequenz=100000
-D I2CBMP280Adr=0x76
-D b2Wire=true
-D bScanI2C=false
-D bI2CBMP280=true
-D bI2CSCD41=true
-D bG2Y10Dust=false
-D bDHT_Sensor=false
-D bPMS5003=false
-D MMC_DAT3=10
-D MMC_DAT=11
-D MMC_CLX=12
-D MMC_DAT0=13
-D TOUCH_SDA=4
-D TOUCH_SCL=8
-D bWeatherFunctionsPrint=false
-D bWeatherApiPrint=false
-D bWeatherApiResponsePrint=false
-D TimeOffset=7200
-D AXS_MAX_TOUCH_NUMBER=1
-D RxDsoft=9
-D TxDsoft=14
-D bWebSocket=true
-D bWOKWI=false
-D bWith_Loop=true
-D bSerialDebug=true
-D bShowHeap=false
-D DHT_PIN=-1
-D PMS_EN_PIN=14
-D PMS_TX_PIN=15
-D PMS_RX_PIN=16
-D BME680_SDA=17
-D BME680_SCL=18
-D DateOffsetSeconds=0
-D OTA_PASSWORD='"GigisBoost"'
-D OTA_HOSTNAME='"ESP32-Klima"'
## MMC JC3248W535
#-D SD_MMC_CMD=11
#-D SD_MMC_CLK=12
#-D SD_MMC_D0=13
## MMC Freenove
-D SD_MMC_CMD=38
-D SD_MMC_CLK=39
-D SD_MMC_D0=40
FS
file://./lib/Arduino_GFX-1.5.9.zip
file://./lib/ArduinoJson-7.4.2.zip
file://./lib/MoonRise.zip
file://./lib/ArduinoMoonPhase.zip
lvgl/lvgl @ ^9.4.0
jchristensen/Timezone@^1.2.4
adafruit/Adafruit BusIO@^1.17.0
https://github.com/PaulStoffregen/Time.git
adafruit/Adafruit Unified Sensor@^1.1.15
git@github.com:adafruit/DHT-sensor-library.git
https://github.com/avaldebe/PMserial.git
arduino-libraries/NTPClient@^3.2.1
esp32async/AsyncTCP@^3.4.9
esp32async/ESPAsyncWebServer@^3.8.1
https://github.com/adafruit/Adafruit_BME680.git
; OTA Upload über WLAN
[env:esp32s3_ota]
monitor_echo = yes
; ── IDENTISCHE build_flags wie esp32s3 ──────────
-I src
-I src/ui
-I include
-D BOARD_HAS_PSRAM
-D ScreenWidth=480
-D ScreenHeight=320
-D SCREEN_COUNT=13
-D SDA_1=8
-D SCL_1=9
-D AkkuReadGPIO1=25
-D DHTPIN=5
-D DHTTYPE=DHT21
-D b2Wire=true
-D bScanI2C=false
-D bI2CBMP280=true
-D bI2CSCD41=true
-D bG2Y10Dust=false
-D bPMS5003=false
-D MMC_DAT3=10
-D MMC_DAT=11
-D MMC_CLX=12
-D MMC_DAT0=13
-D TOUCH_SDA=4
-D TOUCH_SCL=8
-D TimeOffset=7200
-D RxDsoft=9
-D TxDsoft=14
-D bWebSocket=true
-D bWOKWI=false
-D bWith_Loop=true
-D bShowHeap=false
-D DHT_PIN=-1
-D PMS_EN_PIN=14
-D PMS_TX_PIN=15
-D PMS_RX_PIN=16
-D BME680_SDA=17
-D BME680_SCL=18
## MMC JC3248W535
#-D SD_MMC_CMD=11
#-D SD_MMC_CLK=12
#-D SD_MMC_D0=13
## MMC Freenove
-D SD_MMC_CMD=38
-D SD_MMC_CLK=39
-D SD_MMC_D0=40
FS
lvgl/lvgl @ ^9.4.0
; ← HIER! außerhalb lib_deps, kein Einrücken!
upload_protocol = espota
upload_port = 192.168.178.126
upload_flags = --port=3232 --auth=GigisBoost
this compile well [platformio]
this
[env:esp32s3_ota]
Compiling .pio\build\esp32s3_ota\lib0d5\lvgl\widgets\spinner\lv_spinner.c.o
Compiling .pio\build\esp32s3_ota\lib0d5\lvgl\widgets\switch\lv_switch.c.o
In file included from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/../misc/../font/../draw/../misc/lv_assert.h:18,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/../misc/../font/../draw/../misc/lv_color.h:17,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/../misc/../font/../draw/lv_draw_buf.h:18,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/../misc/../font/lv_font.h:20,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/../misc/lv_style.h:16,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/lv_obj.h:19,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/lv_label.h:21,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/lv_textarea.h:16,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/lv_spinbox.h:16,
from .pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/lv_spinbox_properties.c:7:
.pio/libdeps/esp32s3_ota/lvgl/src/widgets/property/../spinbox/../textarea/../label/../../core/../misc/../font/../draw/../misc/../stdlib/lv_mem.h:16:10: fatal error: ../lv_conf_internal.h: No such file or directory
#include “../lv_conf_internal.h”
compilation terminated.
Compiling .pio\build\esp32s3_ota\lib0d5\lvgl\widgets\table\lv_table.c.o
*** [.pio\build\esp32s3_ota\lib0d5\lvgl\widgets\property\lv_spinbox_properties.c.o] Error 1
========================================================================================================================================================= [FAILED] Took 108.94 seconds =========================================================================================================================================================
Environment Status Duration
esp32s3_ota FAILED 00:01:48.936
==================================================================================================================================================== 1 failed, 0 succeeded in 00:01:48.936 ====================================================================================================================================================
PS D:__Dokus\Documents\PlatformIO\ZZ_JC3248W535-Wetter-Stadion\JC3248W535_New\zzJC3248W535-LVGL-Wetter-X>
now the ai does not know what to do giving me stupid advices
I would like to get ota done I cleaned the cache
