Hey, good morning.
Cloned it again and this time it seems to be working.
Now I’m getting:
This is the output when I try to create the image:
Hey, good morning.
Now I’m getting:
Okay that looks better but now you must compile the mklittlefs
first. Do a make dist
again that folder, then search for the produced binary, check that it runs, and overwrite your old mklittefs.
Ok, I copied the created file. But the output still the same.
sh: mklittlefs: command not found
What does it say now when you run the file with ./mklittlefs
Here’s the output:
Looks good – and the new mklittlefs
file is now in the same place as the old one?
Have you tried modifying the script to include the ./
at the beginning?
env.Replace (MKSPIFFSTOOL = "./mklittefs")
you may also try and replace it with the absolute path. (pwd
to find out the current working directory.)
Now that almost worked!
Why am I still getting SPIFFS image?
My board_build on the .ini file equals littlefs
The output text “SPIFFS image…” is static and can’t be influenced with the script – it very likely just works now.
Thank you very much Max!
In case anybody else has this problem, my solution was to build mklittlefs from source, and then place it in /usr/local/bin
Good luck!
