Thanks in advance.
I have a few (small) projects which compiled perfectly well last week (and on plenty of previous days) but will now no longer compile under PIO running on vs.code. All seem to suffer from the same errors. I’m at a loss. I did notice some updates happening when I tried to do a little work on one of the projects. Given that pretty much all my projects are AdafruitIO and are ESP32 based, I’m utterly stuck now.
I suspect it’s because some package versions have been updated…
Attached is a screenshot of the problems indicated pre-compile.
Here’s the compiler error output from the same project:
Processing featheresp32-s2 (platform: espressif32; board: featheresp32-s2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32-s2.html
PLATFORM: Espressif 32 (5.0.0) > Adafruit ESP32-S2 Feather Development Board
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
- framework-arduinoespressif32 @ 3.20003.220626 (2.0.3)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
- toolchain-xtensa-esp32s2 @ 8.4.0+2021r2-patch3
Found 53 compatible libraries
|-- Adafruit BME280 Library @ 2.2.2
| |-- Adafruit BusIO @ 1.12.0
| | |-- Wire @ 2.0.0
| | |-- SPI @ 2.0.0
| |-- Adafruit Unified Sensor @ 1.1.5
|-- Adafruit NeoPixel @ 1.10.5
|-- Adafruit IO Arduino @ 4.2.0
| |-- WiFi @ 2.0.0
| |-- Adafruit MQTT Library @ 2.4.2
| |-- ArduinoHttpClient @ 0.4.0
| |-- SPI @ 2.0.0
| |-- WiFiClientSecure @ 2.0.0
| | |-- WiFi @ 2.0.0
| |-- WiFi101 @ 0.16.1
| | |-- SPI @ 2.0.0
|-- SPI @ 2.0.0
|-- Wire @ 2.0.0
Compiling .pio/build/featheresp32-s2/lib212/WiFi101/WiFi.cpp.o
Compiling .pio/build/featheresp32-s2/lib212/WiFi101/WiFiClient.cpp.o
Compiling .pio/build/featheresp32-s2/lib212/WiFi101/WiFiMDNSResponder.cpp.o
Compiling .pio/build/featheresp32-s2/lib212/WiFi101/WiFiSSLClient.cpp.o
In file included from /home/john/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s2/include/newlib/platform_include/sys/unistd.h:23,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/sys-include/unistd.h:4,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/sys-include/pthread.h:25,
from /home/john/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s2/include/newlib/platform_include/pthread.h:21,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/xtensa-esp32s2-elf/no-rtti/bits/gthr-default.h:48,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/xtensa-esp32s2-elf/no-rtti/bits/gthr.h:151,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/ext/atomicity.h:35,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/bits/basic_string.h:39,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/string:52,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/stdexcept:39,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/array:39,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/tuple:39,
from /home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/include/c++/8.4.0/functional:54,
from /home/john/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.h:49,
from /home/john/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:167,
from .pio/libdeps/featheresp32-s2/WiFi101/src/utility/WiFiSocket.h:28,
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFi.cpp:36:
/home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/sys-include/sys/unistd.h:30:9: error: conflicting declaration of C function 'int close(int)'
int close (int __fildes);
In file included from .pio/libdeps/featheresp32-s2/WiFi101/src/utility/WiFiSocket.h:24,
.pio/libdeps/featheresp32-s2/WiFi101/src/socket/include/socket.h:1839:15: note: previous declaration 'sint8 close(SOCKET)'
NMI_API sint8 close(SOCKET sock);
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiClient.cpp:20:
.pio/libdeps/featheresp32-s2/WiFi101/src/WiFi.cpp: In member function 'int WiFiClass::init()':
.pio/libdeps/featheresp32-s2/WiFi101/src/WiFi.cpp:303:36: error: invalid conversion from 'void (*)(uint8_t*, uint32_t)' {aka 'void (*)(unsigned char*, unsigned int)'} to 'tpfAppResolveCb' {aka 'void (*)(unsigned char*, long unsigned int)'} [-fpermissive]
registerSocketCallback(socket_cb, resolve_cb);
.pio/libdeps/featheresp32-s2/WiFi101/src/socket/include/socket.h:1047:79: note: initializing argument 2 of 'void registerSocketCallback(tpfAppSocketCb, tpfAppResolveCb)'
NMI_API void registerSocketCallback(tpfAppSocketCb socket_cb, tpfAppResolveCb resolve_cb);
.pio/libdeps/featheresp32-s2/WiFi101/src/WiFi.cpp: At global scope:
.pio/libdeps/featheresp32-s2/WiFi101/src/WiFi.cpp:1133:10: error: no declaration matches 'uint32_t WiFiClass::getTime()'
In file included from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFi.cpp:38:
.pio/libdeps/featheresp32-s2/WiFi101/src/WiFi101.h:157:16: note: candidate is: 'long unsigned int WiFiClass::getTime()'
unsigned long getTime();
.pio/libdeps/featheresp32-s2/WiFi101/src/WiFi101.h:79:7: note: 'class WiFiClass' defined here
class WiFiClass
*** [.pio/build/featheresp32-s2/lib212/WiFi101/WiFi.cpp.o] Error 1
*** [.pio/build/featheresp32-s2/lib212/WiFi101/WiFiClient.cpp.o] Error 1
In file included from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiClient.h:28,
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFi101.h:35,
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiMDNSResponder.h:27,
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiMDNSResponder.cpp:32:
.pio/libdeps/featheresp32-s2/WiFi101/src/socket/include/socket.h:1839:15: error: conflicting declaration of C function 'sint8 close(SOCKET)'
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiMDNSResponder.cpp:31:
/home/john/.platformio/packages/toolchain-xtensa-esp32s2/xtensa-esp32s2-elf/sys-include/sys/unistd.h:30:9: note: previous declaration 'int close(int)'
*** [.pio/build/featheresp32-s2/lib212/WiFi101/WiFiMDNSResponder.cpp.o] Error 1
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiSSLClient.h:23,
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiSSLClient.cpp:20:
from .pio/libdeps/featheresp32-s2/WiFi101/src/WiFiClient.h:23,
*** [.pio/build/featheresp32-s2/lib212/WiFi101/WiFiSSLClient.cpp.o] Error 1
================================================================ [FAILED] Took 3.38 seconds ================================================================
* The terminal process "platformio 'run'" terminated with exit code: 1.
