**Pessoal estou com problemas no meu codigo, aparecendo essa mnsagem de erro
" ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset"**
O códgo foi desenvolvido para ESP32, montei uma placa agora para ESP12F, mas sempre da erro. Alguem pode me ajudar? O codgo fonte, vai abaixo: Obrigado Pessoal"
#include <WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// Add porta usb
//sudo chmod 666 /dev/ttyUSB0
// Testar:
#define rele1 13 // 7
#define rele2 12 // 5
#define rele3 9 // 11
#define rele4 10 // 12
#define conexao 4 // 3
#define saida 6 // 6
#define ldr A0 // 2
#define WLAN_SSID "digiteSeuUsuario" // Your SSID
#define WLAN_PASS "***************" // Your password
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883 // use 8883 for SSL
#define AIO_USERNAME "Usuario"
#define AIO_KEY "*************" // Replace with your Project Auth Key
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
/****************************** Feeds ***************************************/
// Setup a feed called 'onoff' for subscribing to changes.
Adafruit_MQTT_Subscribe Light1 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/rele1"); // FeedName
Adafruit_MQTT_Subscribe Light2 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/rele2");
Adafruit_MQTT_Subscribe Light3 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/rele3");
Adafruit_MQTT_Subscribe Light4 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/Rele4");
void MQTT_connect();
pinMode(rele1, OUTPUT);
pinMode(rele2, OUTPUT);
pinMode(rele3, OUTPUT);
pinMode(rele4, OUTPUT);
pinMode(conexao, OUTPUT);
pinMode(ldr, INPUT);
digitalWrite(conexao, LOW);
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
delay(500);
Serial.print(".");
Serial.println();
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Setup MQTT subscription for onoff feed.
mqtt.subscribe(&Light1);
mqtt.subscribe(&Light2);
mqtt.subscribe(&Light3);
mqtt.subscribe(&Light4);
digitalWrite(rele1, HIGH);
digitalWrite(rele2, HIGH);
digitalWrite(rele3, HIGH);
digitalWrite(rele4, HIGH);
MQTT_connect();
Adafruit_MQTT_Subscribe *subscription;
while ((subscription = mqtt.readSubscription(20000))) {
if (subscription == &Light1) {
Serial.print(F("Got: "));
Serial.println((char *)Light1.lastread);
int Light1_State = atoi((char *)Light1.lastread);
digitalWrite(rele1, Light1_State);
if (subscription == &Light2) {
Serial.println((char *)Light2.lastread);
int Light2_State = atoi((char *)Light2.lastread);
digitalWrite(rele2, Light2_State);
if (subscription == &Light3) {
Serial.println((char *)Light3.lastread);
int Light3_State = atoi((char *)Light3.lastread);
digitalWrite(rele3, Light3_State);
if (subscription == &Light4) {
Serial.println((char *)Light4.lastread);
int Light4_State = atoi((char *)Light4.lastread);
digitalWrite(rele4, Light4_State);
void MQTT_connect() {
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
digitalWrite(conexao, HIGH);
