Hi there, I am having trouble building a ESP32 program, as the ESP32 library is buggy and refuses to work.
This is the response of when I try to build it:
> Executing task in folder PrototypeV7: C:\Users\Jason\.platformio\penv\Scripts\platformio.exe run <
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 52 compatible libraries
|-- <EspSoftwareSerial> 6.12.2
|-- <ESP_WiFiManager> 1.3.0
| |-- <WiFi> 1.0
|-- <SoftwareSerial> 1.0.0
|-- <ArduinoOTA> 1.0.0+sha.7856de7
| |-- <WiFi> 1.0
|-- <ESP32 HomeKit SDK for Arduino> 1.1.0
|-- <STM32duino X-NUCLEO-NFC03A1> 1.0.1
| |-- <SPI> 1.0
|-- <SinricPro_Generic> 2.8.0
| |-- <ArduinoJson> 6.17.3
| |-- <WebSockets_Generic> 2.4.1
| | |-- <EthernetENC> 2.0.0
| | | |-- <SPI> 1.0
| | |-- <Ethernet2> 1.0.4
| | | |-- <SPI> 1.0
| | |-- <Ethernet3> 1.5.5
| | | |-- <SPI> 1.0
| | |-- <Ethernet> 2.0.0
| | | |-- <SPI> 1.0
| | |-- <EthernetLarge> 2.0.0
| | | |-- <SPI> 1.0
| | |-- <WiFi> 1.0
| | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| |-- <Ethernet> 2.0.0
| | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| |-- <WiFi> 1.0
|-- <CMSIS DSP> 1.0.0+sha.fa8d1f7
|-- <CR95HF library>
| |-- <ESP32 BLE Arduino> 1.0.1
| |-- <SPI> 1.0
| |-- <WiFi> 1.0
|-- <SPI> 1.0
|-- <WiFi> 1.0
Compiling .pio\build\esp32dev\src\main.c.o
Compiling .pio\build\esp32dev\lib6df\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\lib6df\WiFi\WiFiUdp.cpp.o
Archiving .pio\build\esp32dev\libe41\libESP_WiFiManager.a
In file included from src\main.c:20:0:
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\SPI\src/SPI.h:30:1: error: unknown type name 'class'
class SPISettings
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\SPI\src/SPI.h:31:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\SPI\src/SPI.h:40:1: error: unknown type name 'class'
class SPIClass
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\SPI\src/SPI.h:41:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\SPI\src/SPI.h:88:8: error: unknown type name 'SPIClass'
extern SPIClass SPI;
In file included from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/Print.h:27:0,
from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFi.h:27,
from src\main.c:21:
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/Printable.h:25:1: error: unknown type name 'class'
class Print;
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/Printable.h:33:1: error: unknown type name 'class'
class Printable
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/Printable.h:34:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFi.h:27:0,
from src\main.c:21:
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/Print.h:34:1: error: unknown type name 'class'
class Print
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/Print.h:35:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFi.h:28:0,
from src\main.c:21:
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:29:1: error: unknown type name 'class'
class IPAddress: public Printable
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:29:16: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:94:7: error: unknown type name 'IPAddress'
const IPAddress INADDR_NONE(0, 0, 0, 0);
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:94:29: error: expected declaration specifiers or '...' before numeric constant
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:94:32: error: expected declaration specifiers or '...' before numeric constant
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:94:35: error: expected declaration specifiers or '...' before numeric constant
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPAddress.h:94:38: error: expected declaration specifiers or '...' before numeric constant
In file included from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFi.h:29:0,
from src\main.c:21:
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPv6Address.h:29:1: error: unknown type name 'class'
class IPv6Address: public Printable
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\cores\esp32/IPv6Address.h:29:18: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
In file included from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFiSTA.h:28:0,
from C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFi.h:32,
from src\main.c:21:
C:\Users\Jason\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFiGeneric.h:28:22: fatal error: functional: No such file or directory
compilation terminated.
Compiling .pio\build\esp32dev\libdbd\SoftwareSerial\SoftwareSerial.cpp.o
*** [.pio\build\esp32dev\src\main.c.o] Error 1
.pio\libdeps\esp32dev\SoftwareSerial\SoftwareSerial.cpp:41:27: fatal error: avr/interrupt.h: No such file or directory
*** [.pio\build\esp32dev\libdbd\SoftwareSerial\SoftwareSerial.cpp.o] Error 1
===================================================================== [FAILED] Took 43.32 seconds =====================================================================
The terminal process "C:\Users\Jason\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Please help.
Thank you!
