After doing trials for several weeks with unit test, I came to the conclusion that there is a problem with native unit tests for larger projects. So I wrote this topic to describe it and maybe some day PlatformIO can come with a solution.
Say you are working on a larger project (>10K lines of code)
- you organise your code into ‘libraries’ which are under ‘lib’. It cannot be avoided that some of these have hardware dependencies
- but some are hardware independent, so you want to unit test them in ‘native’
- problem is that the native environment takes ALL of lib, and tries to compile it, (even if not being used by the test-application) and this build fails because of missing definitions in the native platform…
Simple example : say you have some lib using Arduino Serial.print()
You have another lib doing a circular buffer, with no hardware dependencies.
So you want to unit test the circular buffer, but when compiling all stuff in lib, it fails because Serial is undefined…
Kind regards, Pascal Roobrouck
