hi im writing a code with c++ using arduino platform for esp32 wroom and im using vs code and platformio extention. i wrote a simple code that connects to wifi and gets ping from a server. in normal situation it works correctly but the problem i have is that when i turn off the wifi router while the esp is running and turn it back on it takes about 15 seconds for esp to connect to wifi and then it takes about 1.5 minute to get a successful ping response. the odd thing is that if i use mobile phone hotspot internet it pings instantly i use esp32 platform version 6.81 and here is my code.
how can i resolve this issue ? by the way i checked the server ping with command prompt of windows its fine.
thanks in advance
#include <WiFi.h> // use Arduino's standard WiFi library
#include "ESP32Ping.h"
#include <WiFi.h>
#include <ArduinoHttpClient.h>
const char* ssid = "a"; // Replace with your Wi-Fi SSID
const char* password = "87654321"; // Replace with your Wi-Fi password
const char* pingAddress = "socket.mydnspanel.com"; // Domain to ping
IPAddress dns1IP = IPAddress(8, 8, 8, 8);
IPAddress dns2IP = IPAddress(8, 8, 4, 4);
unsigned long previousMillis = 0;
const long interval = 1000; // Check Wi-Fi connection every 1 second
WiFiClient wifi;
HttpClient client = HttpClient(wifi, "socket.mydnspanel.com", 8593);
void connectToWiFi();
void resetWiFiModule();
connectToWiFi();
unsigned long currentMillis = millis();
// Aggressively check for Wi-Fi connection status every second
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Wi-Fi disconnected, resetting Wi-Fi module...");
resetWiFiModule();
connectToWiFi();
} else {
Serial.println("Wi-Fi connected!");
if (client.connect("socket.mydnspanel.com",8593)) {
Serial.println("client connected successfully!");
} else {
Serial.println("client connect failed.");
void connectToWiFi() {
WiFi.begin(ssid, password);
Serial.print("Connecting to Wi-Fi");
WiFi.waitForConnectResult(2000);
// Serial.printf("wifi status is %hhu",wifi_status_check);
WiFi.config(WiFi.localIP(), WiFi.gatewayIP(), WiFi.subnetMask(),dns1IP,dns2IP);
unsigned long startAttemptTime = millis();
const long connectionTimeout = 5000; // Set a 5-second timeout for Wi-Fi connection
while (WiFi.status() != WL_CONNECTED && millis() - startAttemptTime < connectionTimeout) {
Serial.print(".");
delay(500);
if (WiFi.status() == WL_CONNECTED) {
Serial.println("\nConnected to Wi-Fi!");
} else {
Serial.println("\nFailed to connect to Wi-Fi.");
void resetWiFiModule() {
// Disconnect and turn off Wi-Fi to reset the module
WiFi.disconnect(true); // true means also disable the WiFi
delay(1000); // Small delay to ensure proper reset
WiFi.mode(WIFI_STA); // Reinitialize WiFi as station mode
