I’m working on a PIO project using c++17 as standard and the mingw-w64 gcc compiler. When building I get lots of errors like
‘__sv_check’ is not a member of ‘std’
‘__c_locale’ was not declared in this scope
For me it seems like the gcc compiler and the c++ version aren’t working together well because most of the errors come from blocks in the header files that ar in a #if __cplusplus >= 201703L condition.
I made sure to include all the necessary header files and everything but I cannot get it to work.
Does anyone know how to fix this or had issues of this kind before?
What’s the gcc --version that is being used here?
What’s the platformio.ini and minimal code that reproduces the issue?
gcc version is
gcc.exe (i686-posix-dwarf-rev0, Built by MinGW-W64 project) 8.1.0
Copyright (C) 2018 Free Software Foundation, Inc.
the improtant platformio.ini code is
[env:native]
platform = native
${common.build_flags}
-std=c++17
-DTARGET_NATIVE
lib_ignore =
HALTarget
and one of the examples where it gives me an error:
#ifndef _BASIC_STRING_H
#define _BASIC_STRING_H 1
#pragma GCC system_header
#include <ext/atomicity.h>
#include <ext/alloc_traits.h>
#include <debug/debug.h>
#if __cplusplus >= 201103L
#include <initializer_list>
# include <string_view>
// some code...
//some other code...
template<typename _Tp>
_If_sv<_Tp, basic_string&>
append(const _Tp& __svt, size_type __pos, size_type __n = npos)
__sv_type __sv = __svt;
return _M_append(__sv.data()
+ std::__sv_check(__sv.size(), __pos, "basic_string::append"),
std::__sv_limit(__sv.size(), __pos, __n));
#endif // C++17
there it says that ‘__sv_check’ is not a member of ‘std’
What is a simple main.cpp with which the error occurs?
If I take a simple
[env:native]
platform = native
build_flags = -std=c++17
#include <string>
#include <iostream>
int main() {
std::cout << "Hello, world!" << std::endl;
return 0;
it works fine.
>pio run -v
Processing native (platform: native; build_flags: -std=c++17)
Found 1 compatible libraries
g++ -o .pio\build\native\src\main.o -c -std=c++17 -DPLATFORMIO=50200 -Iinclude -Isrc src\main.cpp
g++ -o .pio\build\native\program.exe .pio\build\native\src\main.o -L.pio\build\native
========================================================================================== [SUCCESS] Took 1.31 seconds ==========================================================================================
C:\Users\Max\temp\native_c17>.pio\build\native\program.exe
Hello, world!
But I also have
g++ (MinGW-W64 x86_64-posix-seh, built by Brecht Sanders) 10.2.0
from here.
Ok, so I researched a bit more and i think my problem is similar to the one in this thread. I will try the solution mentioned there, but thanks for your help ![]()
Are you sure? I don’t see anything that related in there.
Can you post the whole project maybe if you still get errors?
Ok, so I finally figured out my problem(s). I reinstalled mingw and chose “seh” as exception handling option. I also had some linux header files in my includes that hat to be replaced.
