I’m using a union to store the config register of a TI TMP117 temperature sensor:
typedef union ConfigRegister {
struct {
bool unused : 1;
bool soft_reset : 1;
bool alert_pin_select : 1;
bool pin_pol : 1;
bool therm_alert_mode : 1;
uint8_t avg : 2;
uint8_t conv : 3;
uint8_t mode : 2;
bool EEPROM_busy : 1;
bool data_ready : 1;
bool alert_low : 1;
bool alert_high : 1;
} bits;
uint16_t reg;
ConfigRegister() {
reg = 0;
} ConfigRegister;
I read the register from the sensor, flip the bytes to fix endianness and store the data in reg. If read the value 0x2220
from the sensor, I expect the values in the union to be:
bool unused = 0b;
bool soft_reset = 0b;
bool alert_pin_select = 0b;
bool pin_pol = 0b;
bool therm_alert_mode = 0b;
uint8_t avg = 01b;
uint8_t conv : 100b;
uint8_t mode : 00b;
bool EEPROM_busy : 0b;
bool data_ready : 1b;
bool alert_low : 0b;
bool alert_high : 0b;
but instead, the values are:
bool unused = 0b;
bool pin_pol = 0b;
uint8_t avg = 01b;
uint8_t conv : 010b;
uint8_t mode : 00b;
bool EEPROM_busy : 1b;
bool data_ready : 0b;
so the most significant byte seems to be shifted by one bit, conv seems to start at the first bit of the most significant byte instead of the last bit of the least significant byte.
I am not sure if this is a straddling issue or not, because I am using a similar union (with bit fields spanning 2 bytes) for a different sensor which works just fine:
struct {
uint8_t unused0 : 4;
uint16_t value : 12;
bool unused1 : 1;
uint8_t pd_mode : 2;
uint8_t unused2 : 2;
uint8_t write_mode : 3;
} bits;
uint8_t content[3];
DataWrite() {
memset(content, 0, 3);
} DataWrite;
I’m compiling with arm gcc 9.2.1 (mbed 6.2.0 for a STM32F407)
Does anyone know what the issue could be?
