I have some issues with the analog read function of my STM32L082KZ. I have made a custom variants, peripherals file etc. to integrate the board into the PlatformIO environment. In the past (1/2 years ago) it worked perfectly fine but now when i try to use the analogread function it always returns 0. I know for certain it worked with the PA6 pin, but PA 4 and 5 are new pins i want to connect and i know they have slightly different functionality.
I have written a small code to test the functionality:
pinMode(PA4, INPUT);
pinMode(PA5, INPUT);
pinMode(PA6, INPUT);
Serial.print("Digital: ");
Serial.print(digitalRead(PA4));
Serial.print(", ");
Serial.print(digitalRead(PA5));
Serial.print(", ");
Serial.println(digitalRead(PA6));
delay(1000);
adcvalue = analogRead(PA4);
Serial.print("Analog: ");
Serial.print(adcvalue);
Serial.print(", ");
Serial.print(analogRead(PA5));
Serial.print(", ");
Serial.println(analogRead(PA6));
delay(1000);
This code shows that when using digitalRead the pin does register a voltage but analogread still returns 0.
My variants.cpp file is built as follows:
// Digital PinName array
const PinName digitalPin[] = {
PC_14, // D0
PC_15, // D1
PA_8, // D2
PA_0, // D3 STM32: ADC_IN0
PA_15, // D4 Arduino: SS(D4) STM32: NSS
PA_11, // D5
PA_12, // D6
PA_13, // D7
PA_14, // D8
PB_7, // D9
PA_4, // D10 Arduino: SS1(D10) STM32: NSS / ADC_IN4 / DAC_OUT1
PB_5, // D11 Arduino: MOSI(D11) STM32: MOSI
PB_4, // D12 Arduino: M1S0(D12) STM32: MISO
PB_3, // D13 Arduino: SCK(D13) STM32: SCK
PA_10, // D14 Arduino: SDA(D14) STM32: SDA_1
PA_9, // D15 Arduino: SCL(D15) STM32: SCL_1
PA_1, // D16 STM32: ADC_IN1
PA_2, // D17 STM32: ADC_IN2
PA_3, // D18 STM32: ADC_IN3
PB_6, // D19
PA_5, // D20 STM32: ADC_IN5 / DAC_OUT2
PA_6, // D21 STM32: ADC_IN6
PA_7, // D22 STM32: ADC_IN7
PB_0, // D23 STM32: ADC_IN8 / Vref_OUT
PB_1, // D24 STM32: ADC_IN9 / Vref_OUT
// Analog (Ax) pin number array
const uint32_t analogInputPin[] = {
0, // A0, PA0
1, // A1, PA1
2, // A2, PA2
3, // A3, PA3
4, // A4, PA4
5, // A5, PA5
6, // A6, PA6
7, // A7, PA7
16, // A8, PB0
17 // A9, PB1
