Problem uploading program into STC89C52RC board
I was trying to set up my computer to run some program on a STC89C52RC board, but something strange happed when I uploading the program. When I use Platform IO to upload the program, it will proceed to "Cycling power: done“ and my board shut down before I do anything. The word “done” appeared with “Cycling Power:”. At this step the power button won’t do anything when I press it. And the board will when back to normal when I stop the program manually in Platform IO or I disconnect and reconnect the USB cable.
But the same thing won’t happed when I use terminal to upload the program, the word “done” won’t pop up before I restart the board, and the program will run on the board with no issue. Can anyone help me with the problem?
Attached is an example of where I get stuck with the program:
> Executing task: platformio run --target upload <
Processing stc89c52rc (platform: intel_mcs51; board: stc89c52rc)
CONFIGURATION: https://docs.platformio.org/page/boards/intel_mcs51/stc89c52rc.html
PLATFORM: Intel MCS-51 (8051) (1.2.3) > Generic STC89C52RC
HARDWARE: STC89C52RC 11MHz, 512B RAM, 8KB Flash
 - tool-stcgal 1.104.0 (1.4)
 - toolchain-sdcc 1.30804.10766 (3.8.4)
Found 0 compatible libraries
Checking size .pio/build/stc89c52rc/firmware.hex
Flash: [          ]   2.8% (used 230 bytes from 8192 bytes)
AVAILABLE: stcgal
CURRENT: upload_protocol = stcgal
Looking for upload port...
Use manually specified: /dev/tty.wchusbserial14610
Uploading .pio/build/stc89c52rc/firmware.hex
Cycling power: done
Strange, I don’t really have an idea of what’s going on… Possible timing issues?
You should file a bug at Issues · platformio/platform-intel_mcs51 · GitHub to get help from the developers.
I encounteredb the same issue. I think it’s the problem of uploading protocal? See the line right above “cycling power”, there’s a "-t 11059’. I don’t know if that means baud rate. Maybe there’s a inappropriate setting about USB registers?
I have met the same problem as you. How did you solve it later :sob:
