I’m having problems uploading my binary. Uploading works on the Arduino IDE I have installed on my laptop running Ubuntu 20.04. I have tried changing the upload speed to 57600, as has been suggested on a previous post, but this hasn’t worked. It seems to be auto-detecting the wrong port for some reason.
When I scan the available ports the following is returned. I select the 4th option
— Available ports:
— 1: /dev/ttyACM0 ‘DW5560 - Dell Wireless 5560 HSPA+ Mobile Broadband Mini-Card Modem’
— 2: /dev/ttyACM1 ‘DW5560 - Dell Wireless 5560 HSPA+ Mobile Broadband Mini-Card Data Modem’
— 3: /dev/ttyACM2 ‘DW5560 - Dell Wireless 5560 HSPA+ Mobile Broadband Mini-Card GPS Port’
— 4: /dev/ttyUSB0 ‘USB2.0-Serial’
Here is the error
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.2.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 6 compatible libraries
Checking size .pio/build/uno/firmware.elf
RAM: [= ] 12.6% (used 258 bytes from 2048 bytes)
Flash: [= ] 12.0% (used 3880 bytes from 32256 bytes)
AVAILABLE: arduino
Looking for upload port...
Auto-detected: /dev/ttyACM0
Uploading .pio/build/uno/firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
avrdude done. Thank you.
*** [upload] Error 1
======================================== [FAILED] Took 2.31 seconds ========================================
The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
My platform.ini file
[env:nanoatmega328]
board = nanoatmega328
upload_speed = 57600
