I’m trying to set a following dev environment:
platform_packages =
toolchain-xtensa-esp32@8.4.0+2021r2-patch3
framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#2.0.3
The problem is that my environment always picks up the toolchain-xtensa32 @ 2.50200.97 (5.2.0)
even if it’s not selected. Please check my build log below:
PLATFORM: Espressif 32 (3.5.0+sha.d93c9ef) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 15.96MB Flash
- framework-arduinoespressif32 @ 2.0.3+sha.142fceb
- tool-esptoolpy @ 1.30100.210531 (3.1.0)
- toolchain-xtensa32 @ 2.50200.97 (5.2.0)
Found 70 compatible libraries
milanvujovic:
Your installed Espressif32 platform is outdated – use the most recent one by e.g. writing
platform = https://github.com/platformio/platform-espressif32.git
or
platform = espressif32@5.1.0
in the platformio.ini
@maxgerhardt This solved my issue, but now whenever I change something in platformio.ini, Platformio downloads the platform and I need to wait 10 minutes each time. How can I avoid this?
That happens with platform = espressif32@5.1.0
No, It happens with
Does it work with 5.1.0
still? Then you don’t need the .git one.
@maxgerhardt Seems like this test broke my dev environment. Now even the previous successful configuration doesn’t work. I’m getting the same error as before
platform_packages =
PLATFORM: Espressif 32 (5.1.0+sha.cdd0867) > Espressif ESP32 Dev Module
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3 LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
