Problem setting up ZEPHYR RTOS ENV for teensy
Hello, I am trying to set up a ZEPHYR RTOS project on a teensy 4.1 through vscode using PIO IDE and I get this error message :
PIO Core Call Error: "
The following files/directories have been created in /home/owhenthesaints/Documents/PlatformIO/Projects/P
lib - Put project specific (private) libraries here
Resolving teensy41 dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Processing teensy41 (platform: teensy-ts; board: teensy41; framework: zephyr)
PlatformIO running on linux_x86_64
CONFIGURATION: https://docs.platformio.org/page/boards/teensy-ts/teensy41.html
PLATFORM: Teensy (4.18.0+sha.f2a89fa) > Teensy 4.1
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 7.75MB Flash
DEBUG: Current (jlink) External (jlink)
 - framework-arduinoteensy @ 1.159.0 (1.59)
 - framework-arduinoteensy-ts @ 1.159.0+sha.7e53c09
 - framework-zephyr @ 2.20701.220422 (2.7.1)
 - tool-cmake @ 3.21.3
 - tool-dtc @ 1.4.7
 - tool-gperf @ 3.0.4
 - tool-ninja @ 1.7.1
 - toolchain-arm-cortexm-linux @ 13.2.0-5+sha.e9efc43
TypeError: expected str, bytes or os.PathLike object, not NoneType:
 File "/home/owhenthesaints/.platformio/penv/lib/python3.10/site-packages/platformio/builder/main.py", line 173:
 File "/home/owhenthesaints/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Script/SConscript.py", line 609:
 File "/home/owhenthesaints/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Script/SConscript.py", line 279:
 File "/home/owhenthesaints/.platformio/platforms/teensy-ts/builder/main.py", line 186:
 File "/home/owhenthesaints/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Util/envs.py", line 251:
 File "/home/owhenthesaints/.platformio/packages/framework-zephyr/scripts/platformio/platformio-build-pre.py", line 25:
 env.ProcessProgramDeps()
 File "/home/owhenthesaints/.platformio/penv/lib/python3.10/site-packages/platformio/builder/tools/piobuild.py", line 121:
 File "/home/owhenthesaints/.platformio/penv/lib/python3.10/site-packages/platformio/builder/tools/piobuild.py", line 347:
 SConscript(env.GetFrameworkScript(name), exports="env")
 File "/home/owhenthesaints/.platformio/packages/tool-scons/scons-local-4.6.0/SCons/Script/SConscript.py", line 673:
 return method(*args, **kw)
 File "/home/owhenthesaints/.platformio/platforms/teensy-ts/builder/frameworks/zephyr.py", line 27:
 SConscript(
 File "/home/owhenthesaints/.platformio/packages/framework-zephyr/scripts/platformio/platformio-build.py", line 1223:
 codemodel = get_cmake_code_model(west_manifest)
 File "/home/owhenthesaints/.platformio/packages/framework-zephyr/scripts/platformio/platformio-build.py", line 286:
 run_cmake(manifest)
 File "/home/owhenthesaints/.platformio/packages/framework-zephyr/scripts/platformio/platformio-build.py", line 263:
 result = exec_command(cmake_cmd, env=zephyr_env)
 File "/home/owhenthesaints/.platformio/penv/lib/python3.10/site-packages/platformio/proc.py", line 114:
 with subprocess.Popen(*args, **kwargs) as p:
 File "/usr/lib/python3.10/subprocess.py", line 971:
 self._execute_child(args, executable, preexec_fn, close_fds,
 File "/usr/lib/python3.10/subprocess.py", line 1783:
 env_list.append(k + b'=' + os.fsencode(v))
 File "/usr/lib/python3.10/os.py", line 811:
 filename = fspath(filename) # Does type-checking of `filename`.
========================== [FAILED] Took 0.85 seconds ==========================
Thanking you in advance for you kind help :slight_smile:.
This indidicates that the CMake tool wasn’t found although PlatformIO should have included it; weird.
Can you do a clean reinstall?
  1. Close VSCode
  2. rm -rf ~/.platformio
  3. Reopen VSCode
