Problem nwith platformio and mac M1
%23 Description of problem
Leave a comment…
BEFORE SUBMITTING, PLEASE SEARCH FOR DUPLICATES IN
%23 Configuration
VSCode: 1.75.1
PIO IDE: v3.3.3
System: Darwin, 24.0.0, arm64
%23 Exception
Error: TypeError: Traceback (most recent call last):
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/platformio/__main__.py", line 103, in main
  cli()  %23 pylint: disable=no-value-for-parameter
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/click/core.py", line 1157, in __call__
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/click/core.py", line 1078, in main
  rv = self.invoke(ctx)
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/platformio/cli.py", line 85, in invoke
  return super().invoke(ctx)
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/click/core.py", line 1688, in invoke
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/click/core.py", line 1434, in invoke
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/click/core.py", line 783, in invoke
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/platformio/home/cli.py", line 92, in cli
  run_server(
File "/Users/henrirulquin/.platformio/penv/lib/python3.12/site-packages/platformio/home/run.py", line 66, in run_server
  if not os.path.isdir(contrib_dir):
File "<frozen genericpath>", line 42, in isdir
TypeError: stat: path should be string, bytes, os.PathLike or integer, not NoneType
`python -m pip install -U platformio` command
  at /Users/henrirulquin/.vscode/extensions/platformio.platformio-ide-3.3.3-darwin-arm64/node_modules/platformio-node-helpers/dist/index.js:1:11001
  at ChildProcess.i (/Users/henrirulquin/.vscode/extensions/platformio.platformio-ide-3.3.3-darwin-arm64/node_modules/platformio-node-helpers/dist/index.js:1:4621)
  at ChildProcess.emit (node:events:526:28)
  at ChildProcess.emit (node:domain:475:12)
  at maybeClose (node:internal/child_process:1092:16)
  at Socket.<anonymous> (node:internal/child_process:451:11)
  at Socket.emit (node:events:526:28)
  at Socket.emit (node:domain:475:12)
  at Pipe.<anonymous> (node:net:687:12)
Mhm, not sure why the contrib_dir would be null. Better cleanly reinstall it.
rm -rf /Users/henrirulquin/.platformio
then use the installer script to reinstall the core. Then restart VSCode.
thanks, it’s work now
