Hey Guys,
I’m getting an error when trying to install PlatformIO through VS Code. My user folder DOES have spaces in it and is an administrator. I tried enabling the general Admin account and changing it, but when I rename the folder, it says it can’t because the folder is in use, blah blah blah. I even tried renaming it after restarting the computer, still in use. Here are the logs:
ExtensionService.ts:840 Extension 'ms-toolsai.jupyter cannot use PROPOSED API (must started out of dev or enabled via --enable-proposed-api)
console.ts:137 [Extension Host] runCommand C:\Users\John A. Del Ponte\.platformio\python3\python.exe
Array(2)
Object
console.ts:137 [Extension Host] Git installation not found.
Array(8)
Object
console.ts:137 [Extension Host] Error: Error: Compatible PlatformIO Core not found.
Reason: PlatformIO executable not found in `C:\Users\John A. Del Ponte\.platformio\penv\Scripts`
at c:\Users\John A. Del Ponte\.vscode\extensions\platformio.platformio-ide-2.2.1\node_modules\platformio-node-helpers\dist\index.js:1:879275
at ChildProcess.c (c:\Users\John A. Del Ponte\.vscode\extensions\platformio.platformio-ide-2.2.1\node_modules\platformio-node-helpers\dist\index.js:1:879169)
at ChildProcess.emit (events.js:223:5)
at ChildProcess.cp.emit (c:\Users\John A. Del Ponte\.vscode\extensions\platformio.platformio-ide-2.2.1\node_modules\cross-spawn\lib\enoent.js:34:29)
at maybeClose (internal/child_process.js:1021:16)
at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
Array(2)
Object
Array(1)
Object
notificationsAlerts.ts:40 Error: Traceback (most recent call last): File "C:\Users\John A. Del Ponte\.platformio\.cache\tmp\get-platformio-0.3.5.py", line 69, in <module> main() File "C:\Users\John A. Del Ponte\.platformio\.cache\tmp\get-platformio-0.3.5.py", line 61, in main bootstrap() File "C:\Users\John A. Del Ponte\.platformio\.cache\tmp\get-platformio-0.3.5.py", line 47, in bootstrap pioinstaller.__main__.main() File "C:\Users\John A. Del Ponte\.platformio\.cache\tmp\.piocore-installer-e5cpn2ic\tmpdqzml0fc\pioinstaller.zip\pioinstaller\__main__.py", line 122, in main File "C:\Users\John A. Del Ponte\.platformio\.cache\tmp\.piocore-installer-e5cpn2ic\tmpdqzml0fc\pioinstaller.zip\cli...
DevTools failed to load SourceMap: Could not load content for https://ticino.blob.core.windows.net/sourcemaps/ea3859d…/node_modules/windows-process-tree/lib/index.js.map: Unknown error
