i tried using vscode in manjaro to build firmware i get this error
Processing mega2560 (board: megaatmega2560; platform: atmelavr@~3.4; framework: arduino) ---------------------------------------------------------------------------------------------------------------------------------------------- Error: Traceback (most recent call last): File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/main.py”, line 121, in main cli() # pylint: disable=no-value-for-parameter File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/click/core.py”, line 1128, in call return self.main(*args, **kwargs) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/click/core.py”, line 1053, in main rv = self.invoke(ctx) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/commands/init.py”, line 44, in invoke return super(PlatformioCLI, self).invoke(ctx) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/click/core.py”, line 1659, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/click/core.py”, line 1395, in invoke return ctx.invoke(self.callback, **ctx.params) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/click/core.py”, line 754, in invoke return __callback(*args, **kwargs) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/click/decorators.py”, line 26, in new_func return f(get_current_context(), *args, **kwargs) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/commands/run/command.py”, line 134, in cli process_env( File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/commands/run/command.py”, line 176, in process_env result = {“env”: name, “duration”: time(), “succeeded”: ep.process()} File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/commands/run/processor.py”, line 67, in process result = init_platform(self.options[“platform”]).run( File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/commands/platform.py”, line 322, in init_platform return PlatformFactory.new(name) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/platform/factory.py”, line 52, in new pkg = PlatformPackageManager().get_package(pkg_or_spec) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/package/manager/base.py”, line 236, in get_package for pkg in self.get_installed(): File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/package/manager/base.py”, line 209, in get_installed pkg = PackageItem(pkg_dir) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/package/meta.py”, line 405, in init self.metadata = self.load_meta() File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/package/meta.py”, line 440, in load_meta return PackageMetaData.load(manifest_path) File “/home/kostas/.platformio/penv/lib/python3.9/site-packages/platformio/package/meta.py”, line 391, in load data = json.load(fp) File “/usr/lib/python3.9/json/init.py”, line 293, in load return loads(fp.read(), File “/usr/lib/python3.9/json/init.py”, line 346, in loads return _default_decoder.decode(s) File “/usr/lib/python3.9/json/decoder.py”, line 337, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File “/usr/lib/python3.9/json/decoder.py”, line 355, in raw_decode raise JSONDecodeError(“Expecting value”, s, err.value) from None json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0) ============================================================ An unexpected error occurred. Further steps: * Verify that you have the latest version of PlatformIO using pip install -U platformio command * Try to find answer in FAQ Troubleshooting section
