I recently updated PlatformIO and Cmake (3.16 minimum was required). Since then linker doesn’t seem to see my lib.
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: espidf)
PLATFORM: Espressif 32 1.12.0 > DOIT ESP32 DEVKIT V1
- framework-espidf 3.40000.200303 (4.0.0)
- tool-cmake 3.16.4
- tool-ninja 1.7.1
- toolchain-esp32ulp 1.22851.190618 (2.28.51)
- toolchain-xtensa32 2.80200.200226 (8.2.0)
Found 0 compatible libraries
Compiling .pio/build/esp32doit-devkit-v1/esp-idf/src/main.c.o
Generating LD script .pio/build/esp32doit-devkit-v1/esp32_out.ld
Generating partitions .pio/build/esp32doit-devkit-v1/partitions.bin
Compiling .pio/build/esp32doit-devkit-v1/esp-idf/spi_flash/partition.c.o
Compiling .pio/build/esp32doit-devkit-v1/esp-idf/spi_flash/spi_flash_rom_patch.c.o
src/main.c:8:10: fatal error: lighting.h: No such file or directory
* Looking for lighting.h dependency? Check our library registry!
* CLI > platformio lib search "header:lighting.h"
* Web > https://platformio.org/lib/search?query=header:lighting.h
#include <lighting.h>
compilation terminated.
Compiling .pio/build/esp32doit-devkit-v1/esp-idf/spi_flash/spi_flash_chip_drivers.c.o
*** [.pio/build/esp32doit-devkit-v1/esp-idf/src/main.c.o] Error 1
I’ve linked a simple code just to isolate the issue.
Thanks ![]()
https://drive.google.com/drive/folders/1Za33f2RwFFFB9QcGrx4mEVMO3hOZxR1E?usp=sharing
