Hello, I have been trying for hours to include a private library with no success. I am using VSCode in portable mode with PlatformIO. I have placed the header files (test.h and test.cpp) according to the instructions in the /lib/test/ folder. The test.h file seems to be recognized and included, but not the test.cpp file. Here is an example project:
main.ccp
#include "test.h"
Serial.println();
Serial.println("test");
//Serial.println("test");
doSome();
test.h
#ifndef TEST_H
#define TEST_H
void doSome(void);
test.ccp
#include "test.h"
#include <stdio.h>
void doSome(void) {
static int i;
i++;
//printf("test")
terminal output when compiling:
Processing adafruit_feather_esp32_v2 (platform: espressif32; board: adafruit_feather_esp32_v2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_feather_esp32_v2.html
PLATFORM: Espressif 32 (2023.1.1) > Adafruit Feather ESP32 V2
HARDWARE: ESP32 240MHz, 320KB RAM, 8MB Flash
- framework-arduinoespressif32 @ 2.0.6
- tool-esptoolpy @ 1.40404.0 (4.4.4)
Found 32 compatible libraries
|-- test
Compiling .pio\build\adafruit_feather_esp32_v2\src\main.cpp.o
Linking .pio\build\adafruit_feather_esp32_v2\firmware.elf
c:/users/christian/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\adafruit_feather_esp32_v2\src\main.cpp.o:(.literal._Z4loopv+0x0): undefined reference to `doSome()'
c:/users/christian/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\adafruit_feather_esp32_v2\src\main.cpp.o: in function `loop()':
C:\Dev\ESP32\test/src/main.cpp:10: undefined reference to `doSome()'
*** [.pio\build\adafruit_feather_esp32_v2\firmware.elf] Error 1
============================================================================================================================================================================== [FAILED] Took 2.66 seconds ==============================================================================================================================================================================
* The terminal process "C:\Users\Christian\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
I’m not sure if this issue could be related to using the portable version of VSCode and the non-portability of PlatformIO.
